Old 06-23-2015, 04:54 PM   #1
TJB_902
Drives: 2015 FR-S 6MT
Possible Steering Issue ?
The other day I had someone slam their brakes on in front of me to avoid hitting a cat, forcing me to do the same. The ABS engaged, but I still knew I wasn't going to be able to stop in time as it was raining, so to avoid rear ending him I was forced to try and quickly turn into a side street (thank god it was there). I managed to stop safely without hitting anything (as did he), but as I was jamming the brakes and trying to make the turn, the back end kicked out sending the car sideways a little bit, all the while the ABS still pulsing like crazy. Ever since the incident my steering feels as though it is "looser" than normal (requires more input and doesn't seem to stick to the road as well). I am wondering if jamming the brakes so hard that it threw the car sideways while taking the turn could have damaged something that would make my steering feel more loose the way it does? or maybe I am just imagining it because I'm paranoid about the car being hurt? lol
TJB_902 is offline   Reply With Quote
Old 06-23-2015, 05:43 PM   #2
chas3wba0
chas3wba0's Avatar
Drives: Yes
Most likely just paranoia... modern cars are designed to perform emergency stops repeatedly without ill effect.
Is the steering wheel still pointing straight? Did any of your tires lock up?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 06-23-2015, 06:11 PM   #3
TJB_902
yeah, steering wheel is still straight and alignment seems fine as well (doesn't pull when wheel is let go). Hard to say if the tires locked up or not, but I would assume they must have in order for it to throw the back end out?
Old 06-23-2015, 06:35 PM   #4
chas3wba0
chas3wba0's Avatar
Drives: Yes
I was more curious on whether your fronts locked up, which might have created some flat spots that cause the front to feel like it isn't "sticking" as well when steering, but it's unlikely, thanks to ABS.
I think you're fine. You say you didn't hit anything, which is the best-case scenario, so it's hard to say what might have affected your steering.
Old 06-23-2015, 07:03 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
you're probably over thinking it!
Old 06-24-2015, 01:38 AM   #6
Turdinator
Señor Member
Turdinator's Avatar
I also think you are probably worried about nothing. However playing devils advocate, perhaps the unusual and extreme loads from the pulsing brakes has torn or damaged a bush in the front end. It should be easy for someone who knew what they were looking at to spot if that was the case.
1974 TA22 Celica
2013 86 GT
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
