Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-06-2021, 10:24 PM   #99
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I wish Tire Rack would get a Gen 2 in for measurements and test-fitting so that their interactive wheel and tire guide could be used...
Haha, great point!
Where (state, city) do they do those measurements?
Any locals who already own a 2022?
Old 12-06-2021, 11:31 PM   #100
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by timurrrr View Post
Haha, great point!
I believe they do the measuring/testing at their South Bend, Indiana location. It was somewhere like that back when they did the measuring for the first gen.
The Following User Says Thank You to Lonewolf For This Useful Post:
timurrrr (12-07-2021)
Old 12-07-2021, 08:51 AM   #101
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Tire fitment issues in the rear
Eh, tire rack is so conservative with offsets they won’t recommend anything more than a few 5mm away from stock in my experience. The offset on a set of OZs they recommended for my Audi were actually 2mm less aggressive than stock.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
DocWalt (12-07-2021), OkieSnuffBox (12-07-2021)
Old 12-07-2021, 09:12 AM   #102
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Here's 18x9 +50 wrapped into 235/40R18:
Looks like they're using a ~10 mm spacer in the front only to get ~40 effective offset:
Source:
Key timestamps: specs at 3:00, close-ups at 0:55 and 1:40; rear brakes (no spacer) at 1:09, front brakes (spacer) at 1:11 and 1:38.
That's pretty frustrating, needing to run a lower offset (wheel further out) up front than the rear.
Robertw is offline   Reply With Quote
Old 12-07-2021, 09:23 AM   #103
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Not really a big deal, it's super easy to run spacers up front and just have wheels with the same offset all around. Not as easy since now you need extended studs but there are kits to get it all at once.
Old 12-07-2021, 09:23 AM   #104
sds
Drives: '22 BRZ Limited 6MT
They could also be trying to equalize track width front and rear. Stock, the front is a little over an inch narrower than the rear.
sds is offline   Reply With Quote
Old 12-07-2021, 10:10 AM   #105
Robertw
Robertw's Avatar
If that's the case, that's fine.
I agree it's not a huge deal, just have to get hub centric spacers. I didn't like the ideal of a wider front track width, but another poster mentioned the front is narrower.
Old 12-07-2021, 10:28 AM   #106
OkieSnuffBox
Drives: '23 BRZ Limited
Yep, you beat me to it. It's going to take companies like CSG and the like to get it really dialed in. Which is why, since I don't need a car at the moment, I may try to stay patient for the '23 BRZ.
Still a bummer that they would give less room out back for a wheel/tire combo than the 1st gen.
Old 12-07-2021, 03:02 PM   #107
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Looks like 255/35R18 tires on 18x9.5 et45's can be squeezed in, with a bunch of camber. Might be the most aggressive fitment (wrt the outside of the tire) that still works:
Old 12-07-2021, 03:53 PM   #108
dsc_pat
Drives: Too fast
This looks super tucked in to be honest...
dsc_pat is offline   Reply With Quote
The Following 2 Users Say Thank You to dsc_pat For This Useful Post:
OkieSnuffBox (12-07-2021), Pete (12-07-2021)
Old 12-07-2021, 05:03 PM   #109
OkieSnuffBox
*snip*
I wonder how much camber that is? When it's pulling out of the pits, it almost looks like there is more camber out back than up front, which is typically the opposite of how you want things to be.
I'm curious to see how much room can be gained with just a roll, not a roll and pull. Of course, even with just a roll you can risk cracking the paint.
Old 12-07-2021, 05:41 PM   #110
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
Those wheels look really nice, and just about perfect offset in relation to the fenders. Could maybe go a little wider with the rubber to reduce the chance of curb rash.
slipstream8 is offline   Reply With Quote
The Following User Says Thank You to slipstream8 For This Useful Post:
Old 12-07-2021, 05:51 PM   #111
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
I think with something less wide than the Yokohamas A052's, you could run this setup on stock camber in the back. My 255/40/17 Yoks are pinched pretty good on the 9" wheels.
trippinbillies40 is offline   Reply With Quote
Old 12-07-2021, 05:54 PM   #112
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Maybe just a couple of mm more than I'd want to.
The perfect flush fitment of the wheel at ride height sure looks nice, but isn't necessarily the best option when the suspension can move.
As highlighted in other pics on this thread, there's a badly placed bump in the fender liner that the tire needs to avoid when the suspension is compressed.
Yup, looks like too much rear camber for the track indeed. But not enough to be qualified as stance yet, I guess.
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
