#29 | |
Drives: unlimited cheap build N/A track car
I would bet there is a Japanese guy sitting at a desk at the Subaru factory in japan that made the system that could fix the problem...unfortunately I don't have his email address. |
#30 |
Drives: 2014 GT86
As with car stock, with less grippy tires, with stock alignment, it's unlikely for problem to occur, i somewhat doubt for there to be official fix. Unfortunately twins with at least stock alignment, are not of optimal setup to track often. Even more so, if updated EPS is among new features of restyle model, and even though if not among major, but extra incentive/selling point. And actual engineers in most big companies are almost never possible to reach directly by customer according common practices. So i guess, that any possible fixes for older twins EPS will probably be unofficial and may probably come from own experiments or will from community.
#31 |
Drives: None
Is there a fix / hack for this yet? I ran my SC'd car yesterday for the first time and this was happening all over the place, I thought it was wheel on hard part at first until I found no evidence and I did a bit of reading online.
I run a Koyo unit in my Miata that looks very, very similar to the BRZ one and have never had an issue, so I'm pretty surprised to find out the cause here.
#32 |
Drives: 2023 BRZ
Yes, stop letting your front tires rub inside your wheel wells. Increase the ride height, get stiffer springs, etc.
Director of Rocky Mountain 86CUP
| The Following User Says Thank You to Pat For This Useful Post: | Icecreamtruk (12-07-2021) |
#33 |
Drives: None
Tires are not rubbing anywhere, 600lb / 700lb springs, ~130mm to pinch weld, etc. Only driven the car one event so far, pace was TT4 record pace in what will be a TT3 car so a few seconds off TT3.
#34 |
Drives: JRSC BRZ SOLD
Someone makes an upgraded motor for the EPS. I just can't remember the manufacturer.
#35 | |
Drives: '22 BRZ
I had this issue plenty on my 2013 even with no bind or rubbing. Annoying.
#36 | ||
Drives: None
![]() Quote:
I wonder if the revised units will plug and play in older cars
#37 | |
Drives: Nevermorange FRS
I have scuffs on my LCA where my massive Eibach sway bar occasionally just skimmed it when I had the length of my end links set wrong.
PRO86 | WTCC | STL
Last edited by rice_classic; 12-06-2021 at 12:31 PM. Reason: Edit: scuff is not spelled skuff... good lord I need to not respond from my phone. |
| The Following User Says Thank You to rice_classic For This Useful Post: | RedReplicant (12-06-2021) |
#38 | |
Drives: None
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | Pat (12-06-2021), rice_classic (12-06-2021) |
#39 |
Drives: '13 FRS - STX
Slap some painters tape on the spot to see if it happens again.
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | CrowsFeast (12-10-2021), Icecreamtruk (12-07-2021) |
#40 |
Drives: Track preped NA FRS
Im with most people here on that its probably rubbing somewhere. If its happening everywhere (or very often) its not the EPS cutting out, that only happens under very heavy load, so usually cambered turns or big elevation changes at turn in points. Since you didnt post any pictures of it, look UP inside your wheel wells. The tire usually rubs on the black plastic (fender liners) right above the tire at max compression if you are too low, and 130mm is very low.
#41 |
#42 | ||
Drives: None
I found the marks previously shown from the bar endlinks and I also found that close to lock at full droop the remote reservoir lines were being stretched, so I cleaned that up. It only happened under heavy trail braking or mid corner where load was highest. I have another test day next weekend, so we will see if it has cleared up. Quote:
The units look very similar to what I ran in my Miata, which is a Koyo from a Saturn Vue (and other cars). The Pro Street ECU looks the same as my control unit and also has the same harness w/ rheostat to control assist. I would be kind of curious to see what failsafe mode is like on the units we have. Normal assist or turns off completely?
| The Following User Says Thank You to RedReplicant For This Useful Post: | Icecreamtruk (12-10-2021) |
| Steering issue under braking ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 146 | 04-25-2023 05:47 PM |
| Possible Steering Issue ? | TJB_902 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 06-24-2015 01:38 AM |
| power steering | ender2664 | Engine, Exhaust, Transmission | 32 | 03-21-2015 04:16 PM |
| Steering wheel issue | Khalis | Issues | Warranty | Recalls / TSB | 1 | 05-04-2013 01:19 AM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
