Old 11-19-2021, 10:29 AM   #1
mjh712
BRZilla
mjh712's Avatar
Drives: '13 WRB BRZ Limited MT
Upgrading my rear suspension questions
After my 100,000 mile inspection my mechanic informed me that I need a new right rear strut & mount (Yay PA Roads), & a new lower left ball joint/control arm. I figured it's probably best to just re-do both back struts at this point, replace everything in pairs & everything.
For the rear suspension I'm planning on upgrading to the Bilstein B6s, but was curious what new mounts to get with them. This is a daily driver & I'm not too familair with suspension parts. I was looking at the KYB Strut Mount, but figured it might be worth it to upgrade to a Raceseng or Vorshlag Spherical Mounts. I just don't know why the Raceseng has 1" and 2" options & what perch I'd need. (Again, no idea what I'm looking for).
I also noticed people recommended installing whiteline rear subframe inserts. Would that be worth it since I'm replacing the struts?
I'm currently planning on sticking with the OEM shocks. Unless there's a reason or cheap upgrade I should be doing.
For the left lower ball joint arm, it's apparently bent. (Again, Yay PA Roads - Specifically looking at you Boulevard Overpass Contruction Crew) is this something I'm fine just replacing the left one of? Any aftermarket upgrades that aren't too expensive?
mjh712 is offline   Reply With Quote
Old 11-19-2021, 10:46 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
B6s are an upgrade. I'd recommend doing all 4 together.
For strut mounts, stick with OEM.
Old 11-19-2021, 05:21 PM   #3
Purist
Purist's Avatar
Drives: Subaru BRZ
Consider adjustable LCAs in case you want to lower it later. Not much price difference.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 11-19-2021, 07:44 PM   #4
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Other than a defective new one, struts should basically always be done in pairs (both front or both rear).
But frankly as suggested I would just bite the bullet and do all four at once. Especially if you are upgrading.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 11-25-2021, 07:57 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by mjh712 View Post
...For the rear suspension I'm planning on upgrading to the Bilstein B6s...
...I'm currently planning on sticking with the OEM shocks...
Huh??
1974 TA22 Celica
2013 86 GT
Old 11-30-2021, 03:01 PM   #6
mjh712
BRZilla
mjh712's Avatar
Originally Posted by Turdinator View Post
Huh??
meant coils
Old 12-08-2021, 02:33 PM   #7
Ernest72
I would do all 4. It might be worth it to do RCE yellow coils, only lowers 20mm and many people like them with B6.
Old 12-22-2021, 12:36 PM   #8
mjh712
BRZilla
mjh712's Avatar
Alright, leaning toward doing all 4. My shop recommended replacing all the strut mounts as well because if I'm replacing the struts & the one mount is already degrading, it's probably best to just do all of them & be all new rather than potentially have to wait for another part after things get taken apart.
So, Looking at
-B6 Front & Back
-Assuming I should include new Strut Boots
-Stick with OEM Springs or the RCE Yellows
-Strut Mounts - OEM
However, the OEM Front Strut Mounts say they're not available & the "replacement" product says it doesn't fit with the 2013.... Any other mounts people recommend? I found a few threads mentioning Pedders, but they're currently sold out on front mounts.
Old 12-22-2021, 01:39 PM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
See below
So, Looking at
-B6 Front & Back This sounds like a nice upgrade in ride quality
-Assuming I should include new Strut Boots Not necessary unless yours are torn
-Stick with OEM Springs or the RCE Yellows RCE will be lower and stiffer, if that's something you'd like, go for it
-Strut Mounts - OEM If you keep OEM or go RCE springs, just use the original top hats. Its probably not necessary to get new ones unless the rubber isolators are in really bad shape.
BigTuna is offline   Reply With Quote
Old 12-22-2021, 02:31 PM   #10
Racecomp Engineering
I agree with BigTuna, but I would replace the strut mounts. Anything OEM 2013-2020 will fit your car. I posted some part numbers in this thread:
https://www.ft86club.com/forums/showthread.php?t=142230
- Andrew
Old 12-22-2021, 02:36 PM   #11
RToyo86
RToyo86's Avatar
OEM front mounts are the same across the board for FRS/BRZ.
If you find something that fits a 2017 it fits the 2013 too.
Edit I was beat too it.
Old 12-22-2021, 04:15 PM   #12
mjh712
BRZilla
mjh712's Avatar
- Andrew
So, the 20320AA113 will fit even though all but one parts website say it does not fit the 2013 model?
Old 12-23-2021, 08:30 AM   #13
mjh712
BRZilla
mjh712's Avatar
Okay, now the parts websites are saying it does fit...
Old 12-23-2021, 08:45 AM   #14
I made a call and Subaru fixed it.
Jk I have no idea what happened. Sometimes the parts websites are clunky.
- Andrew
bilstein, control arm, top hats
Upgrading 2013 suspension to 2017. Parts needed? armstrom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-14-2021 12:52 PM
"Upgrading" BRZ suspension without lowering holeeray Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 12-03-2020 09:43 PM
Upgrading from RCE Yellow AutoX setup to coilovers... questions Keenercarguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-10-2017 09:47 PM
looking into upgrading suspension Mattygt86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-09-2015 11:46 AM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
