Old 03-01-2014, 03:12 AM   #1
Astroboy
Astroboy's Avatar
Drives: None
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2
I'm currently thinking about getting the avo stage 1 turbo kit for my car but am actually more impressed by the results of the stage 1.5 and stage 2 kit. I spoke with somebody from avoturboworld and they told me the the only differences between the stage 1 and stage 1.5/2 were the exhaust pipes, 8psi actuator, and 3 bar map sensor, but while I was reading the drift office's stage 1.5 thread they said they used a slightly bigger turbo, does anybody know the exact size turbo that drift office was using? And are the 3 bar map sensor, 8psi actuator, and exhaust pipes really the only differences? Because if that's the case, since I already have a full headerback exhaust, then i figured I'd just get the stage 1 and add the other components I would need to get the stage 1.5/2 results later since the stage 1 is a lot cheaper by 2 grands.
I was also looking at the full blown turbo kit and was very impressed by their results also. compared to the avo turbo kit, which would your prefer if you only wanted somewhere around 250-290hp and 180-200lbs of torque with linear lines on the dyno chart. Also which one would be better if you wanted higher low end torque.
Astroboy is offline   Reply With Quote
Old 03-01-2014, 04:13 PM   #2
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
There's a forced induction section.
JohnJuan is offline   Reply With Quote
Old 03-01-2014, 06:21 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by JohnJuan View Post
I know but the tapatalk ipad app is difficult to figure out, and that's where I started the thread, anywAys can you answer any of my questions?
Sent from my LG-D800 using Tapatalk
Old 03-01-2014, 07:13 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I make 300/260 on a dyno dynamics dyno on 93 pump gas with
Base avo kit
Stock over pipe
2.5" front pipe and Perrin cat back
Dw700 injectors
3 bar map
10.5psi of boost with manual boost controller
Flex fuel, higher wastegate actuator, ecu controlled boost controller soon to come
Old 03-01-2014, 07:29 PM   #5
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
The simple answer is that the turbocharger supplied with the Stage 1 turbo kit does not change between Stage 1, 1.5 (which is a Drift Office supplied build) and Stage 2 (AVO official stage 2). All that changes is supporting hardware.
The base turbocharger on the kit has done 240whp at 5psi of boost, and 350whp at 12.5psi of boost. What changes is the supporting modifications - boost actuator and exhaust plus tune, race gas or e85, and a clutch that is able to take that torque. And, of course, dyno tuning.
AVOturboworld is offline   Reply With Quote
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 04:45 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Engine, Exhaust, Bolt-Ons 56 09-22-2012 03:28 PM
