Old 10-26-2021, 02:12 PM   #15
Ernest72
2 nice UOAs at 25k and 50k using either Subaru 0W20 or Motul 0W20. At 68k, next one at 75k. DD and spirited driving. Some high revs, but no rev limiter.
Old 10-27-2021, 05:19 AM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by ZDan View Post
I don't think anyone should be concerned about what the viscosity is at 40C.
it's useful for calculating viscosity curves ~
Old 10-27-2021, 08:07 AM   #17
7 skulls
Drives: 2014 scion frs
https://www.widman.biz/English/Calcu...erational.html
Find the viscosity of your oil online, plug it into the calculator. Add in the max sustained oil temp you see and bang. If your cSt answer is less than 7.5 (see my previous post), you need a thicker oil. If your already running a HD 5w30, then you need an oil cooler.
7 skulls is offline   Reply With Quote
Old 10-27-2021, 08:34 AM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
I guess? But just from "0W20" or "5w30" you already know viscosity at 0C and at 100C. I wouldn't use the 40C number to extrapolate beyond that range.
On the hot side, you usually have an HTHS at 150C number to go by.
And on the cold side, if you live where it gets *very* cold, you have CCS and pour point temp.
Old 10-27-2021, 09:00 AM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think HTHS is more important than extrapolated viscosity for high rpm/high temperature operation at the track. IMO run oil with HTHS >=3.5 cP @150C and yer good up to pretty high oil temps...
I'm running Redline 5w30 (3.7 HTHS) at 275F max oil temp at the track for ~15 minute stints, ~4 stints per track day, and change it out after 4-6 track days. Your calculator says 6.3 cSt at 135C(275F). So be it... If I was running much longer stints or endurance racing, I might run an oil cooler.
Old 10-27-2021, 10:42 AM   #20
7 skulls
[QUOTE=ZDan;3476240]I think HTHS is more important than extrapolated viscosity for high rpm/high temperature operation at the track. IMO run oil with HTHS >=3.5 cP @150C and yer good up to pretty high oil temps...
Can't argue with that either. HTHS 3.5 or more for the Castrol I run so I'm happy. Kinimatic viscosity calculations mimic well what i saw with 5w30 and with 0w20. Hated watching oil pressure drop off with the 0w20 at temps matched by the numbers. If I push the 5w30, I should see the same drop off somewhere north of 118C. No race tracks around here unfortunately.
I determined a while ago that the risks associated with a cooler weren't worth it for my usage and the numbers say I don't need one. Interested in your UOAs and oil pressures. Not being a smart ass. Really glad someone is out there running this car hard without a cooler.
Old 10-27-2021, 11:22 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
What did oil pressure drop from/to?
Yer fine and correct to ask, but I don't have pressure data and haven't done UOAs. If I was worried that I was on the limits either way, I'd monitor, but I'm somewhat relying on UOAs done by others who have tracked without coolers, running similar max oil temperatures to me and haven't seen any unusual or worrying oil degradation or wear metals. For pressure, my understanding is that pressure drop at elevated rpm may be more due to restrictions on the intake side of the pump. https://www.ft86club.com/forums/showthread.php?t=134863
But same source says that "A stock engine can take 7,600 RPM all day long..." so I'm sorta counting on that as well...
42 track days and approaching 60k miles, so far so good
And a few of those track days were with 0w20 so on me for that!
Old 10-27-2021, 04:01 PM   #22
7 skulls
With 0w20, I was seeing low 40s psi at redline and any temp above 105 C. This was probably fine (my UOAs said it was) but I always eased off when I hit 116 C and let it cool. So basically I could get 3 or 4 turns in the upper rev range. On 5w30, I see mid 50s psi up to redline at 118 C and can hang out at high rpm enough to tail a hard running K20Z3 for 15 minutes on a twisty road. Not a track day for sure but enough.
Read that thread on oil pressures. Not seeing the pressure sag at redline with 5w30.
The Following User Says Thank You to 7 skulls For This Useful Post:
ZDan (10-27-2021)
Old 10-29-2021, 11:31 PM   #23
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
damn you hit 275F?
I can't get it past 100C/212F with my engine sitting +4k rpm for 20 minutes runs
Old 11-01-2021, 11:55 AM   #24
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
damn you hit 275F?
That claim seems a bit too good to be true. Much of this is based on outdoor temps of course, so if you're talking about cooler days, then I can I understand. But at 4k+ RPM's for such a long period of time and you're holding at 212F still??? Seems like if that were the case, not a single person would ever consider any type of cooler on this car as a DD.
Dzmitry is offline   Reply With Quote
Old 11-01-2021, 12:02 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Seems about right to me. Averaging about 6k rpm on track for a full session my car runs about 230 +/-10f depending on ambient. I am running a 613 core.
Old 11-01-2021, 12:03 PM   #26
Dzmitry
Dzmitry's Avatar
I possibly missed where he mentioned he has an oil cooler? I just assumed he was stock.
Old 11-01-2021, 07:28 PM   #27
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I got the basic oil-water oil cooler from subaru installed.
Sure my last run wasn't the hottest of days, it was like 91°F outside.
Old 11-02-2021, 08:22 AM   #28
Dzmitry
Dzmitry's Avatar
Got it, so you at least have that cooler, which is likely what is doing the work. Because on an 80 degree day, if I'm cruising on the highway at 3.5K RPM, I will see temps get to around 225-230F. Good to know it keeps your highway temps nice and stable, it's a definite next mod for me just to keep temps in a sweet spot.
Thicker sway bars or leave OEM...? Aztec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-07-2021 02:54 PM
Has anyone fitted a thicker OEM rear bar yet from another Subaru? ft_sjo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-24-2016 07:05 PM
Lucas Oil Oil Stabilizer rev3la7ion BRZ First-Gen (2012+) — General Topics 8 06-10-2014 05:24 AM
thicker headgaskets Calum Forced Induction 17 02-15-2013 06:51 AM
Thicker oil for turbo? Synack Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 08-27-2012 02:58 AM
