Old 08-26-2012, 07:43 PM   #1
Synack
Boosted
Synack's Avatar
Drives: Sideways
Thicker oil for turbo?
I was thinking, wouldn't it be beneficial if I got a thicker weighted oil for both my engine and transmission after going turbo?
Maybe even the diff too?
If so, does anyone have any recommendations?
Old 08-26-2012, 08:43 PM   #2
coyote
coyote's Avatar
Drives: Slowly
Don't guess. Monitor oil temp and pressure, change your oil very frequently to begin with and get it analysed. That'll tell you if the oil is doing the job.
I'd "guess" you may need a 0W30, but please refer to the first two words of my post.
coyote is offline   Reply With Quote
Old 08-26-2012, 08:46 PM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
5w-30 if I turbo would be the first oil and probably what I'd stick to when I turbo
Old 08-26-2012, 09:21 PM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
OK that solves motor oil. What about tranny/diff?
Sent from my Galaxy Nexus
Old 08-26-2012, 09:29 PM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'd double check the ratings as to how much those two can handle .. I think Adv Clutch Tech thread has some blurps about them ..
I still need to replace the oils on them however .. not really liking how the stock fluids are feeling right now
also the engine oil would depend on how much boost you're running & how aggressive .. 52-30 won't cut it for higher boost and more aggressive driving
Old 08-26-2012, 09:52 PM   #6
Synack
Boosted
Synack's Avatar
Drives: Sideways
Max 8psi in the beginning. Maybe 10-11 after a year or so. Moderately aggressive driving.
Sent from my Nexus 7 using Tapatalk 2
Old 08-26-2012, 10:12 PM   #7
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'd try 5w-30 first on that as well heh.
See how it does .. of course you're going to want devices to keep track of oil temps
also ask who you're getting your turbo from and ask some of the other guys that are building a turbo see what they suggest.
Old 08-26-2012, 10:45 PM   #8
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I would be weary about changing the oil viscosity. The main thing you want to worry about for turbos is oil pressure to the turbo. Ball bearing turbos gonna want less pressure than race bearing style turbos, most BB turbos need or usually come with oil restrictors.
The other issue would be either installing a turbo timer or manually resting at idle before you shut off the car. You can cake the lines with burned oil, eventually blocking flow.
If you wanted to protect against this adding an oil cooler would be really helpful. Otherwise most newer turbos you can use viscosities closer to what your engine, internals and gaskets were built for.
Ironsquid is offline   Reply With Quote
Old 08-27-2012, 03:58 AM   #9
cosage31
Truck reversing camera
Drives: BMW
Thicker oil will stay around a bit longer when going through the passages, therefore taking away more heat than thinner oil. This property of thicker oil is key especially for cooling pistons and turbos, and not as much for the rest of the engine, where coolant usually helps take away uneeded heat.
cosage31 is offline   Reply With Quote
AUS turbo 86. vonreal FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 08-26-2012 08:31 AM
Turbo FR-S docyzx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 08-11-2012 03:45 PM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
Do we really want a Turbo BRZ? I'm going to say no. Scubynubie BRZ First-Gen (2012+) — General Topics 140 01-06-2012 10:52 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
