Old 02-05-2013, 11:28 AM   #1
ft_sjo
Drives: GT86
Question Has anyone fitted a thicker OEM rear bar yet from another Subaru?
Hi all
I've heard thoughts/comments/statements/myths about other OEM Subaru bars fitting the rear of the GT86/BRZ.
1) Have you done it?
2) What bushes did you use?
edit: Got part numbers for the three OEM rear bars from Subaru:
Subaru Impreza 2007- Parts
Description WRX (16mm) STI (18mm) STI (19mm) Qty
Rear Anti-Roll Bar 20451FG000 20451FG010 20451FG020 1
Rear ARB Bushing 20464FG000 20464FG010 20464FG020 2
Rear ARB Clamp 20466FG000 20466FG000 20466FG000 2
Rear ARM Clamp Bolt 901000303 901000303 901000303 2
Old 02-05-2013, 11:30 AM   #2
OrbitalEllipses
Drives: Attitude
Bill has.
Originally Posted by Scooby South View Post
Rear lower control arms. Swaybars, shocks and springs.. the swaybars and shocks/springs of course are different rates... I have a stock rear bar (14mm) a WRX rear bar (16mm) and a STi rear bar (18mm) for TEH cheap.. any thing from 08 WRX/STi plus
Others have as well, but he's provided the most information. You'd want to use the bushings from those bars.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
ft_sjo (02-05-2013), Scooby South (02-05-2013)
Old 02-05-2013, 12:06 PM   #3
wparsons
wparsons's Avatar
Are the WRX/STi rear bars direct drop ins or do you need to find different end links that'll work, and other brackets?
flickr
Old 02-05-2013, 12:11 PM   #4
OrbitalEllipses
Drives: Attitude
Direct drop in. Rear suspension components for this car were quick to market because they are identical (or at least VERY similar) as 2008-2013 WRX/STI components.
Our end links are the same as theirs. Buy bar, buy correct bushings, fit to car, enjoy.
Old 02-05-2013, 12:13 PM   #5
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Just be careful. If you don't upgrade the front bar as well, you are going to make the car very tail happy.
Ranatsu is offline   Reply With Quote
The Following 2 Users Say Thank You to Ranatsu For This Useful Post:
Neziah (02-05-2013), OrbitalEllipses (02-05-2013)
Old 02-05-2013, 03:00 PM   #6
ft_sjo
Drives: GT86
The car's not neutral enough for me, but thanks!
Old 02-05-2013, 03:19 PM   #7
CaptainSlow
CaptainSlow's Avatar
So you're experiencing understeer currently? That would be the only reason to upgrade the rear sway bar without upgrading the front if you're going for "neutral" handling.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 02-05-2013, 04:37 PM   #8
ft_sjo
Drives: GT86
That's right.
Old 02-05-2013, 05:24 PM   #9
fatoni
haha what? what size shirt do you wear, XM?
Old 02-05-2013, 10:22 PM   #10
CaptainSlow
That's right.
You are not pushing in this car. If you ARE, you are not driving correctly.
I'd suggest some stickier tires. If traction is your issue, that is your best bet to solve it.
Old 02-06-2013, 03:50 AM   #11
ft_sjo
Drives: GT86
Does anyone happen to have the part number for the 16mm rear bar that'll fit and the associated bushings? Thanks.
Old 02-06-2013, 03:56 AM   #12
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Assumming the front is zn6 specific...
zohare is offline   Reply With Quote
Old 02-07-2013, 08:44 AM   #13
Turn in Concepts
Turn in Concepts's Avatar
We are running a 2011 wrx rear bar on our car with stock front, RCE springs, Koni struts/shocks, and AST camber plates. No issues with the car being too tail happy and that is with -3* of negative camber in the front and -1.8* rear with only .1* total toe in rear.
Tony
Turn in Concepts is offline   Reply With Quote
The Following User Says Thank You to Turn in Concepts For This Useful Post:
dsc_pat (03-17-2022)
Old 02-07-2013, 09:03 AM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm amazed at how widely varied the opinions on sway bar sizing is with this car.
Subaru TSB 12-140-12 for Rear Deck Popping sparks Issues | Warranty | Recalls / TSB 31 07-17-2013 12:11 PM
BRZ fitted with LS2 V8 Tman08 Engine, Exhaust, Transmission 9 12-13-2012 07:28 PM
Thicker oil for turbo? Synack Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 08-27-2012 03:58 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 10:22 AM
