#169 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
Stock looks like it gets about 156kw at the wheels, and 227nm of torque. This would translate to 209hp and 167lb/ft =D |
| The Following 3 Users Say Thank You to Blighty For This Useful Post: |
#170 |
Drives: '15 BRZ RA
Apexi's dyno in Japan
Result is 204PS which equals to 201hp. Pretty much close with what the official catalog power says in Japan (235PS / 232hp). With a correction parameter of 1.15 which is the common one for Dynapack it gives 204PS * 1.15 = 234.6PS (at the crank). After installing a full exhaust system (w/o cats) it went to 212PS or 209hp.
| The Following User Says Thank You to nikitopo For This Useful Post: | Simmons (10-23-2021) |
#171 | |
Drives: ‘22 CWP
| The Following 5 Users Say Thank You to Kona61 For This Useful Post: | DocWalt (10-27-2021), DriveDriftDogfight86 (11-24-2021), Jucostud (10-23-2021), Pete (10-23-2021), Yoshoobaroo (10-23-2021) |
#172 |
Drives: '15 BRZ RA
Here is the official Dynapack definition of the 1.15 parameter:
TC Factor - allows user to enter a driveline loss factor (Transmission Correction) to add a percentage of power to the flywheel power graphs. A factor of 1.0 adds no correction factor, a factor of 1.15 would add a 15% correction factor to the flywheel numbers. Axle (rear wheel) numbers are not effected by the TC Factor box. Source: http://www.dynapackusa.com/vehicle.htm |
#173 | |
TRACKBREAD
Dyno Numbers
So a 15% correction factor correlates to a ~13% drivetrain loss. Sounds reasonable. I’ve been hearing 15-20% is too conservative for 15 years, maybe 13% is closer to what modern transmissions achieve. Last edited by Yoshoobaroo; 10-23-2021 at 06:52 PM. |
#174 |
Drives: '23 BRZ Limited
And it's not just transmissions, remember in a RWD car the differential also has to turn the power 90 degrees and more friction. Aside from all the rotating mass.
#175 | |
Drives: VW GLI 6MT
#176 |
Drives: '15 BRZ RA
#177 | |
Drives: 22 BRZ
EDIT: hey I just noticed that this is the first dyno that actually shows peak torque at 3700 RPM
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#178 |
Drives: '22 BRZ
Correct. Seems to gain about the same power as a first gen twin from similar mods and no tune.
#179 |
Drives: GR86 RC
From the newly updated Japan GR site. https://toyotagazooracing.com/jp/gr/...eartbeat_fast/
Anyone knows what's the SAE procedure for getting "certified" dyno numbers? Like ramp rate etc. And how that's different to the dyno runs we are familiar with. Maybe thats why the rpm peaks are all delayed by 200 to 400rpm for the peaks (3200 and 4600 for the aftmkt dynos we see vs 3700 and 5000 in the official numbers). Interesting the max dip in the official dyno is 4400rpm, almost identical to the dip for most aftmkt dynos we see. |
| The Following User Says Thank You to Jianlun For This Useful Post: | Blighty (10-27-2021) |
#180 |
Drives: 2017 Brz
I got a question about dyno numbers. Is that wheel torque or crank torque being measure?
Sent from my SM-G781W using Tapatalk |
#181 |
Purist
Drives: 2013 FRS - Hot Lava
WHP is Wheel Horse Power. That is a rolling dyno for wheel hp numbers. ^^^
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#182 |
Drives: 2017 Brz
I get the whp but is the torque also to the wheel?
| Typical Mustang Dyno Numbers? | Rockz222 | Engine, Exhaust, Transmission | 6 | 07-11-2015 08:33 PM |
| Dyno numbers | ogrowup | Engine, Exhaust, Transmission | 7 | 12-27-2014 08:04 AM |
| Average Stock Dyno Numbers? | KONVERTER | Engine, Exhaust, Transmission | 23 | 10-12-2013 10:13 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| dyno numbers seem low | stealth_fighter | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-02-2013 09:01 PM |
