Drives: FA20Club ELH&CAI, MT,Tinted, Raven
dyno numbers seem low
Hey guys, i just went to the dyno today and my numbers seemed odd. 132HP @ 6400, 127ft-lb TQ @ 2500 & 4500 rpm. It was a Mustang Dyno. No clue what the AFR was. Could the winter grade fuel be the issue? The outside temp was around 8deg.
Drives: FRS
if anything you should be making more power during colder temps.
Drives: 2013 Raven Black FRS
Some mustangs read low...i wouldn't worry.
| The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post: | Freeman (01-31-2013), stealth_fighter (02-01-2013) |
Drives: '13 Black BRZ
Mustang dyno's usually do read lower than Dynojets. From my LS1 Vette days, I remember cars getting 20 or 30whp less on a 400whp car. Don't know if its proportional or not, but I wouldn't be surprised to see that number on a Mustang dyno.
Drives: Supercharged Golf Cart
Just curious as I know nothing of these things...but if this Mustang system is known for giving low numbers, doesn't that equate to the system being basically worthless?
What would be the point of having a system designed to measure HP that always measures lower than it really is? It's like using a broken thermometer to check your temperature. |
Drives: 2013 "AVO Orange" FR-S
It's basically worthless if you want to have numbers to brag about, yes.
But that's not the purpose of a dyno. It's a measuring stick to see if your tuning is doing something or not. It doesn't matter if the baseline is 120 or 180, the idea is to measure the gain from that baseline. |
#7 | |
Drives: 13 GTI
You were at Performance 2ning outside of Dubuque right? I want to get my car dyno'd there sometime. It'd be interesting to compare numbers.
Drives: Asphalt Scion Frs 6MT
Mustang Dynos are called "Heartbreakers" for a reason. They're low reading dynos.
#10 |
I was indeed. My first impression is i like the shop. The guys are pretty knowledgeable and the pricing is on par with what i expected. I would recommend then and will be going back one i get me intake and tune so i can fine tune it.
| Stock FR-S/BRZ shock dyno & stock FR-S spring dyno | xwd | Tracking / Autocross / HPDE / Drifting | 16 | 08-07-2014 09:04 PM |
| dyno numbers based on break in procedure. | EZWood | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 06-09-2013 08:32 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
| Part numbers | 20valvewynn83 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-24-2012 06:16 AM |
