Old 10-18-2021, 09:37 PM   #15
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Originally Posted by DjDATZ View Post
Worked like a charm, thank you! Now to find that button cover and get it ordered!
Sent from my HD1905 using Tapatalk
You can just pull back the trunk lining and unplug the button. You don't have to wait or order anything else.
Joon525 is offline   Reply With Quote
Old 10-18-2021, 11:15 PM   #16
AJ32162
Drives: 2019 BRZ with Performance Package
From what I've read, unplugging the button breaks the circuit and gives the same result as depressing the button. The two contacts on the plug will have to be jumped to enable the trunk to be opened with the release buttons on the dash, trunk lid and key fob.
AJ32162 is offline   Reply With Quote
Old 10-19-2021, 02:08 AM   #17
Originally Posted by villainous_frx View Post
2014 here and formerly winter driven, still need to take it apart and clean everything out of it
It didn’t all get knocked out?
villainous_frx (10-19-2021)
Old 10-19-2021, 04:03 AM   #18
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Unfortunately no? Or fortunately rather, no one seems to have a lava trunk. Not to thread jack, but car should be getting towed to the shop next week. Put her into winter storage mode again yesterday
villainous_frx is offline   Reply With Quote
Old 10-20-2021, 10:19 PM   #19
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
any links to some of those button covers? And, who needs a kick in the groin region for putting that there? Seriously. Anything in the trunk will hit it when you go around a corner. and these cars are all about cruising in straight lines...
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Seized motor/vapor lock after installing Edelbrock 1556 iceblaze Forced Induction 26 12-28-2018 11:24 PM
Trunk button or fob trunk button aren't working. kamilehaula Issues | Warranty | Recalls / TSB 10 10-24-2018 08:33 AM
disable the trunk release cancel button Riftur Electronics | Audio | NAV | Infotainment 19 02-13-2016 01:35 PM
Buzzing/popping sound when HID fog light button is pressed. HELP! gabrielthethird Cosmetic Modification (Interior/Exterior/Lighting) 3 02-08-2015 11:10 PM
when you hit the lock button on your key... pr086 Scion FR-S / Toyota 86 GT86 General Forum 15 11-28-2012 01:55 AM
