EightSixClub Co-Founder
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Trunk Cancel Button Pressed, But Lock Seized
Earlier this week, my trunk stopped opening from the cabin button and the remote. I've had this happen before, so I know I can just unlock the trunk from the lock above the license plate.
However, when I went to try that, it seems the lock has seized. I tried WD-40ing it to get it to release, but no dice. I tried rotating the key so hard that I apparently warped it so much, that I couldn't turn the ignition. (Simple solution to that, I just warped it back.) Given that I don't want to destroy a key, what suggestions that I can try to get it to release? I could try reaching in to get to the straps behind the back seat to see if can pull on them to fold the seat down. Suggestions on how to do this? Sent from my HD1905 using Tapatalk
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Shove your hands through the back seats and pull the rear seat release strap(s). Then get a 3D printed button cover and never worry about it again!
#3 | |
Will ask the fiancée to try ahahWill take a look for the button cover, duct tape will do temporarily! Sent from my HD1905 using Tapatalk
Off to the track!
Using a piece of wire, such as a coat hanger has also worked for me in the past. Good luck!
She couldn't get her hand in and I tried a bunch with a coat hanger and nada.
![]() Sent from my HD1905 using Tapatalk
ProCrastinationConsultant
did you try pushing down on top of the trunk while trying to turn the key? sometimes it relieves enough pressure in the lock assembly to allow it to work.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You're either going to have to get to the straps with some sort of hook, or take out the seat seat cushion, and move the rear side trim our of the way enough to remove the bolts holding the seatback hinge to go through from under.
But on an unrelated note, I was looking at your profile trying to see what year it was for the trunk cylinder to seize from corrosion, and while the year isn't listed, I see you're in toronto with a Kia Rondo... ... Get rid of that hot potato SOON. if you're in canada your cars are subject to rust and those kias have STRUCTURAL FUEL TANKS which are weak to rust, the start to leak from the bottom and cost several thousand dollars to replace. |
#8 | |
Off to the track!
You may be able to pull up the two "buttons" on the top of the back seat. Those are the latches. As I recall they basically work like door locks.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#10 |
Drives: 2019 BRZ with Performance Package
This may help it's from a post by Stang70Fastback on another thread.
"Grab the black plastic trim surrounding the lock mechanism on the top corner of the rear seatback. Pull it up. It snaps right off. The pull up on the red-colored peg to release the seat. Then just snap the cover back on. It's that simple." |
#11 | |
#12 |
Thanks for the tips y'all, will give them a try when I have a little time today!
#13 | |
The Rondo is on its way out, had a spate of a few weeks of going in and out of the mechanic's shop for various repairs. Third time replacing the water pump in about a year and a half. IIRC it's a 2012 or 2011?Sent from my HD1905 using Tapatalk
#14 | |
| Seized motor/vapor lock after installing Edelbrock 1556 | iceblaze | Forced Induction | 26 | 12-28-2018 10:24 PM |
| Trunk button or fob trunk button aren't working. | kamilehaula | Issues | Warranty | Recalls / TSB | 10 | 10-24-2018 07:33 AM |
| disable the trunk release cancel button | Riftur | Electronics | Audio | NAV | Infotainment | 19 | 02-13-2016 12:35 PM |
| Buzzing/popping sound when HID fog light button is pressed. HELP! | gabrielthethird | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 02-08-2015 10:10 PM |
| when you hit the lock button on your key... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-28-2012 12:55 AM |
