#15 |
Drives: 13 Firestorm
Can you do a DIY guide on how to install the resistor?
#16 |
NW Region Moderator
Drives: FR-S No More
Don't really need a DIY... you just hook each lead to the two wires that run to the turn signals right behind the signal assembly. So one wire goes to the positive turn signal wire, and the other goes to the ground. Ummm... maybe someone can remind us of the colors? I forget.
#17 | |
Drives: Scion FantasticRoad-Sex
#18 |
NW Region Moderator
Oops, HunterGreene, I didn't see that you wrote that. I haven't had a chance to locate the flasher unit.
#19 |
Hail Magnet
I got this one off of amazon, works perfectly in my tC:
[ame="http://www.amazon.com/gp/product/B008C9YS0Y/ref=oh_details_o00_s00_i00"]http://www.amazon.com/gp/product/B008C9YS0Y/ref=oh_details_o00_s00_i00[/ame] Just check your manual, I would assume it would be in the DIY section. |
#20 | |
#21 | |
#22 |
Hail Magnet
#23 |
#24 |
NW Region Moderator
I'll be interested to see if this works in the FR-S... I already went with the resistors, but someone else please try this out!
#25 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
#26 | |
Hail Magnet
As you know, the fuses protect the system, but they do not control the turn signals, nor the rate at which they flash at. The clicking noise you get is from the relay, which is usually inside the car somewhere (as I don't have my FR-S yet, I couldn't tell you where it is inside the cabin). That relay is what controls your rate of turn signal flash. The relay, at least on toyota cars, is a little box-like 8-pin unit that plugs into the system. On my car, this is located on a panel that is under the wheel to the left (towards the ouside of the car). It looks like this: ![]() Of course, each car's setup is different, but you should be able to find it if you do a little digging. Hope that clears it up a bit. |
#27 |
It's under the steering column, dead center on the bottom almost.
| The Following User Says Thank You to michaelahess For This Useful Post: | HunterGreene (07-30-2012) |
#28 |
Hail Magnet
Just for reference, here is the pin side:
| Converting side marker to turn signals | ayau | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 12-13-2015 03:41 PM |
| Simple One: Clear Turn Signals | Spaceywilly | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 07-26-2012 02:03 AM |
| Tinted signals and markers | RandomHero | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-19-2012 09:37 PM |
| FRS APR FRONT LIP | sidnacious | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-06-2012 06:50 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 07:43 PM |
