Old 07-28-2012, 07:42 PM   #15
Drunknhero
Drives: 13 Firestorm
Can you do a DIY guide on how to install the resistor?
Drunknhero is offline   Reply With Quote
Old 07-28-2012, 11:25 PM   #16
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Don't really need a DIY... you just hook each lead to the two wires that run to the turn signals right behind the signal assembly. So one wire goes to the positive turn signal wire, and the other goes to the ground. Ummm... maybe someone can remind us of the colors? I forget.
Old 07-30-2012, 12:14 AM   #17
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Originally Posted by HunterGreene View Post
Darren, have you looked to see if the flasher relay is a Toyota or Subaru part? When I put LEDs in the turn signals for my TC, I just replaced the thermal relay with an electronic one (which are readily available for most cars out there), and haven't had any problems since. Took 5 minutes to swap them out.
Got an example of what you are talking about?
Memphis is offline   Reply With Quote
Old 07-30-2012, 12:29 AM   #18
DarrenDriven
NW Region Moderator
Oops, HunterGreene, I didn't see that you wrote that. I haven't had a chance to locate the flasher unit.
Old 07-30-2012, 08:29 AM   #19
HunterGreene
Hail Magnet
HunterGreene's Avatar
I got this one off of amazon, works perfectly in my tC:
[ame="http://www.amazon.com/gp/product/B008C9YS0Y/ref=oh_details_o00_s00_i00"]http://www.amazon.com/gp/product/B008C9YS0Y/ref=oh_details_o00_s00_i00[/ame]
Just check your manual, I would assume it would be in the DIY section.
Old 07-30-2012, 11:34 AM   #20
Memphis
Memphis's Avatar
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
If we can use that then your my hero. No cutting!
Old 07-30-2012, 11:40 AM   #21
Memphis
Memphis's Avatar
Says its a 15 A fuse. Which means it wont work.
Old 07-30-2012, 11:45 AM   #22
HunterGreene
Hail Magnet
Sorry, not following, what are you referring to?
Old 07-30-2012, 11:47 AM   #23
Memphis
Memphis's Avatar
For the turn signals and flashers. Its a 15 A fuse. I did not see any reference to a relay anywhere in the manual.
Old 07-30-2012, 12:43 PM   #24
DarrenDriven
NW Region Moderator
I'll be interested to see if this works in the FR-S... I already went with the resistors, but someone else please try this out!
Old 07-30-2012, 01:15 PM   #25
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
This is what I used on my BRZ, works fine:
http://www.ebay.com/itm/130728541504...ht_3134wt_1159
michaelahess is offline   Reply With Quote
Old 07-30-2012, 01:17 PM   #26
HunterGreene
Hail Magnet
Sadly, I don't have a manual to look at, but let me explain it and see if this clears it up.
As you know, the fuses protect the system, but they do not control the turn signals, nor the rate at which they flash at. The clicking noise you get is from the relay, which is usually inside the car somewhere (as I don't have my FR-S yet, I couldn't tell you where it is inside the cabin). That relay is what controls your rate of turn signal flash. The relay, at least on toyota cars, is a little box-like 8-pin unit that plugs into the system. On my car, this is located on a panel that is under the wheel to the left (towards the ouside of the car). It looks like this:
Of course, each car's setup is different, but you should be able to find it if you do a little digging. Hope that clears it up a bit.
Old 07-30-2012, 03:16 PM   #27
michaelahess
It's under the steering column, dead center on the bottom almost.
The Following User Says Thank You to michaelahess For This Useful Post:
HunterGreene (07-30-2012)
Old 07-30-2012, 03:20 PM   #28
HunterGreene
Hail Magnet
Just for reference, here is the pin side:
Converting side marker to turn signals ayau Cosmetic Modification (Interior/Exterior/Lighting) 30 12-13-2015 03:41 PM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 02:03 AM
Tinted signals and markers RandomHero Cosmetic Modification (Interior/Exterior/Lighting) 2 07-19-2012 09:37 PM
FRS APR FRONT LIP sidnacious Cosmetic Modification (Interior/Exterior/Lighting) 7 07-06-2012 06:50 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
