Old 09-23-2021, 02:20 PM   #15
Phuviano
Drives: FRS RS 2.0 #757
Go get an alignment.
You are probably getting a light because the TCS isn't properly correlating wheel position with wheel speeds.
Will the alignment fix that as well?
Phuviano is offline   Reply With Quote
Old 09-23-2021, 02:21 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes it should. The only other thing it could be is you damaged a wheel speed sensor during the coil over install. You need an alignment anyway.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Phuviano (09-23-2021), strat61caster (09-23-2021)
Old 09-23-2021, 02:24 PM   #17
Phuviano
Thanks, i highly doubt i damaged the sensor, since i was pretty gentle and didn't force those things out. But lets hope for the best.
Coilover install help Aire2thethrone Northern California 4 03-25-2016 10:27 PM
OFT install gone wrong. Webster10 Software Tuning 5 12-16-2015 05:24 PM
Coilover install JerryMichaels7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-05-2014 03:31 PM
Bushing install gone wrong FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 11-13-2013 10:58 PM
Perrin pulley install gone wrong Hops Normal Engine, Exhaust, Transmission 79 01-27-2013 12:20 PM
