Old 12-16-2015, 02:03 PM   #1
Webster10
Drives: 2013 FRS
OFT install gone wrong.
So I received my OFT today. I tried to read my stock ECU and the tablet keeps displaying that an error occured while reading data from the DME. Help?
Webster10 is offline   Reply With Quote
Old 12-16-2015, 02:15 PM   #2
swarb
Explain your procedure when you plug it in, all the way until it gives you the error.
Is it plugged in and on the second click of the ignition, with the engine off?
Try plugging it into a computer and updating it. Or unplugging it and starting all over.
The Following User Says Thank You to swarb For This Useful Post:
murdoc (12-16-2015)
Old 12-16-2015, 02:16 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Make sure that you just have the ignition on, and the engine isn't running.
murdoc is offline   Reply With Quote
Old 12-16-2015, 02:58 PM   #4
Webster10
Drives: 2013 FRS
@murdoc thanks. I was running the engine. *facepalm*
Sent from my SAMSUNG-SM-G925A using Tapatalk
Old 12-16-2015, 04:50 PM   #5
austin_ellas
Drives: Asphalt 2014 FRS
This will help greatly
austin_ellas is offline   Reply With Quote
Old 12-16-2015, 05:24 PM   #6
icybrzzz
Drives: 2015 Scion frz
Make sure to update the tablet before trying to do anything with the tablet!
I also had this issue when I first got mine, once I updated it to the latest firmware it worked perfectly and I had stage 1 within 5minutes.
icybrzzz is offline   Reply With Quote
Something wrong with my DRL's? FRSHunter Scion FR-S / Toyota 86 GT86 General Forum 3 03-26-2014 07:46 PM
What's wrong with this car? Suberman CANADA 41 01-14-2014 12:35 PM
Bushing install gone wrong FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 11-13-2013 10:58 PM
Perrin pulley install gone wrong Hops Normal Engine, Exhaust, Transmission 79 01-27-2013 12:20 PM
