Old 08-27-2014, 02:15 PM   #15
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
And if anyone is wondering what a straight pipe exhaust sounds like at full tilt on track....
@THEmailman is in the video too
[ame="https://www.youtube.com/watch?v=H9YF6BJ2fOM&list=UUI7_3qVwegS7kgSt8P_D3Yw"]https://www.youtube.com/watch?v=H9YF6BJ2fOM&list=UUI7_3qVwegS7kgSt8P_D3Yw[/ame]
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 08-27-2014, 02:28 PM   #16
whataboutbob
AutoX-10/10ths every run
I've hit 1.29G using the Solo DL on 245/40R17 A7s autoxing.
Build thread:Here
Old 08-30-2014, 09:33 AM   #17
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by mav1178 View Post
Before with my S13, if I had issues with hangers popping off I just zip tie the crap out of them to prevent movement.
Probably better than clips and easier to replace, too.
-alex
Haha. I am a former S13 owner and I find it funny how everything on those cars can be fixed with zip ties. Never thought of this though.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 08-31-2014, 08:25 PM   #18
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I switched to Perrin mounts when I installed the cat back. Running on 710's with no issues but I only pull a "measly" 1.2 G's as well
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
smbstyle (09-04-2014)
Old 09-15-2021, 01:41 PM   #19
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Strange, we never had issues, but keep us posted!
Still no issues? I just dropped my exhaust coming through the Watkins Glen Bus stop. Three aftermarket PU hangers of unknown provenance had gotten hot, stretched, cracked, then failed completely. Thereafter the two remaining (autozone) hangers failed. Trying to decide whether OEM hangers will be enough or if I should take this opportunity to reinforce.
gcranston is offline   Reply With Quote
Old 09-15-2021, 02:05 PM   #20
CSG Mike
CSG Mike's Avatar
I stick to OEM hangers; they're compliant and will flex quite a bit without failing, if/when needed.
As with all other rubber parts, they do *eventually* get dry and brittle....
I believe CSG has OEM hangers in stock!
Old 09-15-2021, 02:07 PM   #21
gcranston
Thanks, but so does my local Subaru dealer. Seems like another point to add to the inspection routine...
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et SterlingBrz Audio/Visual, Electronics, Infotainment, NAV 2 04-27-2015 11:45 PM
J2 Quad on stock hangers OURO3OROS Engine, Exhaust, Transmission 18 03-23-2014 09:13 PM
DIY request how to remove stock fr-s rubber exhaust hangers? Team_Kengai DIY (Do-It-Yourself) Guides 2 11-30-2013 01:26 AM
FS: Stock Muffler w/Tips and Stock Airbox Cross Engine, Exhaust, Bolt-Ons 4 09-23-2013 11:24 AM
PBM comps 400 miles bigjake Brakes, Suspension, Chassis 2 05-18-2013 09:38 PM
