Old 08-25-2014, 11:08 AM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Stock Muffler & Hangers w/ R comps
I wanted to bring this up since it has happened on multiple occasions now. Once I switched to R-comps (NT01s), I have had the entire OEM muffler assembly fall off 3 times at 2 different tracks; it literally pops off the hangers and falls onto the ground during high G load cornering, dragging down the track.
So a few months ago I didn't have time to swap the muffler off for the muffler delete before a track event at Sebring, and first session out a few laps in the entire assembly falls onto the ground during cornering and trashed the midpipe. That was the first time I had the stock muffler on when running R-comps (215 NT01s). Luckily the safety crew helped me put it back up so I could drive back to the pits. So I put the muffler delete on at the track and ran fine the rest of the day.
Fast forward to this weekend, I just had a RevWorks UEL header installed, and am running a cat delete, so I ran the first day at Road Atlanta with the muffler delete, and it was just too loud. So I swapped back to the OEM muffler, made sure there was no lubricant on any surface, triple checked it was secure, wiggled back and forth really hard and couldnt get it to pop off at all. So the first session out, 3 laps in at Turn 6 I heard it fell off. Safety crew arrived, and the OEM hangers were still on the muffler, so I went to touch them and they were a lot softer than they were when I initially installed the muffler, and we were able to re-hang the muffler back on with ease, as the metal brackets slipped in with ease.
After we brought it back into the pits, we installed C clips ( like this: http://ecx.images-amazon.com/images/...vL._SX300_.jpg ) in front of every hanger to prevent it from poping off, and ran 2 more sessions with no more issues.
So the issue boils down to the combination of the super heavy OEM muffler, increased cornering load with the R-comps, as well as the OEM exhaust hangers stretching more than they should when hot, allowing the muffler to slip off. Next up are Polyurethane exhaust hangers, and we'll still install the C-clips behind them for good measure.
Just a heads up to anyone else who is going to be running a OEM muffler with R-comps.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
CSG Mike (08-25-2014), Surok (09-22-2014)
Old 08-25-2014, 11:47 AM   #2
wparsons
wparsons's Avatar
Kartboy and Perrin both sell direct fit better hangers, probably a good upgrade for anyone tracking their car.
I'm running the Kartboy hangers with my Perrin exhaust, their exhaust also has clamp on keepers as well.
flickr
whataboutbob (08-25-2014)
Old 08-25-2014, 12:14 PM   #3
whataboutbob
AutoX-10/10ths every run
Perrin bushings on my hangers, I'm running R-Comps too. No issues.
Build thread:Here
Old 08-25-2014, 12:31 PM   #4
ja1217
Drives: 2004 Toyota RAV-4 5M
Weird, I've been stickier r-comps (225 Hoosier R6's) with stock muffler for 5 events this year and haven't had any issues with my stock exhaust on stock hangers. They even survived hitting some roadkill that ripped my diffuser off on the way to the track.
ja1217 is offline   Reply With Quote
Old 08-25-2014, 12:45 PM   #5
smbstyle
smbstyle's Avatar
Do you have any data to see what kind of G load you are seeing in the corners? Not saying this is you, but I know plenty of people that are running DOT slicks and R comps that are no where near the car's or tire's limits. We're at 1.2 G's according to the AIM Solo DL data on the corners that the muffler has fallen off.
2013 SWP BRZ
Old 08-25-2014, 01:01 PM   #6
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
interesting I have been using the same exact tires and even wider size (235/40/17) ever since I purchased this car and attended about 9-10 events so far with 3 different exhausts (stock, Tsudo and Invidia Q300 catback exhausts) and never had this issue.. and I am pretty sure my car sees a lot of lateral Gs I think your issue is the softened hangers most likely due to extreme heat in Florida, I used to live in Tampa Bay so I know how hot it gets during the summer ..
glamcem is offline   Reply With Quote
Old 08-25-2014, 01:22 PM   #7
ja1217
I've managed to hit 1.78g according to my Solo DL, but usually I'm more consistently in the 1.4-1.6g range.
The Following User Says Thank You to ja1217 For This Useful Post:
smbstyle (08-25-2014)
Old 08-25-2014, 01:47 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Before with my S13, if I had issues with hangers popping off I just zip tie the crap out of them to prevent movement.
Probably better than clips and easier to replace, too.
-alex
Old 08-25-2014, 02:13 PM   #9
CSG Mike
CSG Mike's Avatar
Strange, we never had issues, but keep us posted!
Old 08-25-2014, 02:21 PM   #10
vroom4
I think you need to sanity check your data there....1.8 lateral g....yea no....just becuase your logger says it doesnt mean its real or sustained.
vroom4 is offline   Reply With Quote
Old 08-25-2014, 02:31 PM   #11
glamcem
glamcem's Avatar
just curious, have you encountered any oil starvation issues with the R6s? Have you been using any sort of baffled plate and/or dry sump in your car?
Old 08-25-2014, 03:33 PM   #12
ja1217
It wasn't sustained, just peak, which is probably why I don't have any issues with oil starvation. I'm pretty sure its real though. Managed to crack my windshield that weekend. Went into turn 1 with no crack, came out with one.
Old 08-25-2014, 03:34 PM   #13
THEmailman
Drives: Raven 6MT
@smbstyle this is John....I was the one with the black FR-S that was riding along....just thought I would say hi. Hopefully you resolve the issue, I can vouch that the g load plus hopping the curbing at turn 3 will definitely knock it off
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 08-25-2014, 04:29 PM   #14
smbstyle
smbstyle's Avatar
Hey John! Glad you have you out there, it was a good weekend! Yes the turn 3 curbing with the passenger side going airborne may definitely help the muffler come loose lol
2013 SWP BRZ
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et SterlingBrz Audio/Visual, Electronics, Infotainment, NAV 2 04-27-2015 11:45 PM
J2 Quad on stock hangers OURO3OROS Engine, Exhaust, Transmission 18 03-23-2014 09:13 PM
DIY request how to remove stock fr-s rubber exhaust hangers? Team_Kengai DIY (Do-It-Yourself) Guides 2 11-30-2013 01:26 AM
FS: Stock Muffler w/Tips and Stock Airbox Cross Engine, Exhaust, Bolt-Ons 4 09-23-2013 11:24 AM
PBM comps 400 miles bigjake Brakes, Suspension, Chassis 2 05-18-2013 09:38 PM
