Old 09-11-2021, 07:25 PM   #1
RyanOlsen05
Drives: 2013 Widebody FR-S
Power steering not working
Hey, I’m new here. I recently bought my car but the power steering doesn’t work. I checked the fuzes but that’s not the problem. I’m wondering if anyone has any suggestions or has had a similar issue.
RyanOlsen05 is offline   Reply With Quote
Old 09-11-2021, 07:34 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
The Twins have power steering!! What next? MT?
Old 09-11-2021, 07:37 PM   #3
Did you throw your accessory belt? Overheated too?
EPS will not run off of the battery. It runs only from a properly functioning alternator.
JohnH (09-11-2021)
Old 09-11-2021, 10:02 PM   #4
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Interesting, thanks for that info. I might have to use that knowledge at work one day.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 09-11-2021, 10:42 PM   #5
Yeah. It's a nice analog to the old power steering pump. Can still get home if your alternator shits the bed because the servo would otherwise drain the battery pretty quickly.
Other folks reading this, Don't drive without a working water pump. That's a showstopper.
Old 09-11-2021, 11:45 PM   #6
RyanOlsen05
My alternator and belt are both running good
Old 09-12-2021, 12:10 AM   #7
I'm sure that the MIL must be illuminated. Take it to an auto parts store and ask if someone can read the code(s) for you.
Old 09-12-2021, 02:15 PM   #8
mazeroni
Drives: 2013 Scion FR-S Series 10
Does it occasionally work and go out suddenly? Is there a glowing "steering wheel" light in the dash that stays on?
My Power Steering ECU went at around 50K miles. It was $1200 with parts and labor at the dealer. The part online is like $500, the rest is labor. Not sure if you can fix it yourself. I believe part of the labor was having to calibrate it with the Toyota computer, but I'm not totally sure.
In my case, the power steering would work, then randomly go out while driving. Turning off and on the car fixed it temporarily. I did ask them to check the codes before they did anything, but they said the car wouldn't show anything if it was hardware. It didn't. They actually had to leave the car running for about 2 hours before it faulted on its own so they could guarantee it was the ECU because the car didn't log any problems.
mazeroni is offline   Reply With Quote
Old 09-12-2021, 03:12 PM   #9
RyanOlsen05
The power steering light on the dash is on. The power steering never worked, even for the previous owner. Is it common for the power steering ecu to go out? ( for reference it has 137,000km or roughly 85,000 miles)
Old 09-12-2021, 03:24 PM   #10
mazeroni
Not that I've heard on the forums. Not sure the stats. I probably just got unlucky.
* I should add, it could also be the motor itself. In that case, I think the dealer would replace the entire steering assembly which will be much more costly.
Old 09-12-2021, 03:25 PM   #11
RyanOlsen05
I guess that makes 2 of us
Old 09-18-2021, 03:24 AM   #12
My power steering has been not working in my 2013 frs for longer than I’ve owned it. A mechanic said that it is most likely due to having an aftermarket steering wheel and no airbag. I’m not sold on the idea, so I thought I’d come on here and ask around. The reason I think it’s not due to the steering wheel is because the only connections that aren’t being used are the airbags (and that shouldn’t turn off EPS). The codes that are on are… C1515, C1525, U1201, U0073, and U0126. If you have any ideas or suggestions lmk.
I suggest not starting a new thread for the same problem.
Old 09-18-2021, 03:54 AM   #13
C1515/1525 - No biggie. System needs re-initialized.
U0073/U0126 - U0126 is the tell. Busted clock spring. Most likely broken when the steering wheel was first removed.
eps, not working, power steering
Power outlet not working PNW FRS Issues | Warranty | Recalls / TSB 31 01-29-2017 01:59 PM
Power Outlet in Center Console not Working (Not a Blown Fuse) DemonRawr Issues | Warranty | Recalls / TSB 3 06-06-2016 05:14 PM
Power Steering rosol16 Issues | Warranty | Recalls / TSB 15 12-15-2015 10:44 AM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 05:16 PM
Power Outlet Is Not Working Oakhenshield Scion FR-S / Toyota 86 GT86 General Forum 11 01-01-2015 08:41 PM
