Old 01-01-2015, 04:32 AM   #1
Oakhenshield
Oakhenshield's Avatar
Drives: ahh its blue?
Power Outlet Is Not Working
So i havent use the power outlet since i got the car and today i tried to use it but it doesnt work, i tried different car chargers and even bought a new 12v one and then i found a fuse (i think) inside the power outlet and it doesn seem that it was attached to something when i found it and now i want to put it back and try to use the power outlet before going to the dealer tomorrow the only thing is i dont know how.. any help?
sorry for posting again, i found the other thread about this but it doesnt have the solution and seems like abandoned..
Bruuuum Bruuuum!
Oakhenshield is offline   Reply With Quote
Old 01-01-2015, 04:42 AM   #2
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Have you tried the 12V outlet in the glove box? Or just the one in the centre console?
Might want to check the wiring or if you aren't comfortable with that, take it back to the dealer and get them to scope it out.
Wise is offline   Reply With Quote
Old 01-01-2015, 04:52 AM   #3
Oakhenshield
whaat? is there an outlet in the glove box? because what i meant was the one from the cup holder in the center
Bruuuum Bruuuum!
Old 01-01-2015, 06:11 AM   #4
Wise
Circle Work Clerk
There should be, unless the USDM cars don't have them.
Old 01-01-2015, 06:53 AM   #5
Oakhenshield
what in the world!!! i ddnt know about this i just checked it and there is really a power outlet and it also works! im so dumb lol
i think i know now why the power outlet in the cupholder doesnt work its because there was something stuck in there (i think it was a tip from the first car charger i tried because i inserted it and pull it because it was kinda hard to push all the way in and i thought that charger was broken when i pulled it because theres no tip lol)
Anyway how do i remove that thing from there? any step by step to remove the cup holder?
Bruuuum Bruuuum!
Old 01-01-2015, 12:15 PM   #6
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
First bit of this shows you how
http://www.ft86club.com/forums/showthread.php?t=25054
FiRStsc10n is offline   Reply With Quote
Old 01-01-2015, 12:53 PM   #7
extrashaky
Drives: 2014 BRZ Limited
It's in the manual, but if you don't read the manual there's no way you would know it's there. It's impossible to see unless you're looking for it.
FYI, that power outlet in the glove box comes with a black plastic plug. That plug is also the exact size needed to plug the sound hole behind the carpet in the passenger side footwell, so that you're not piping intake noise into the cabin. A lot of people go out and buy one of those plugs for the sound hole, not realizing they already have one that fits perfectly.
Old 01-01-2015, 02:51 PM   #8
Oakhenshield
Originally Posted by FiRStsc10n View Post
seems like a lot of work lol
well i admit i dont read the manual.. and i think i dont have it? is it inside the aid kit because i havent check aid kit yet.. lol
Bruuuum Bruuuum!
Old 01-01-2015, 02:58 PM   #9
Why would you need to remove the cup holder? Just reach in with some needle nose pliers and pull the piece out. This isn't a high tech issue!
Old 01-01-2015, 06:26 PM   #10
Oakhenshield
ahhhhhh? its so tight i cant pull it with long nose because i can only grab a portion of that thing not to mention that the opening was only a quarter size
Bruuuum Bruuuum!
Old 01-01-2015, 07:38 PM   #11
extrashaky
1. Grab cup holder.
2. Lift cup holder.
Old 01-01-2015, 07:41 PM   #12
Obligatory "That's what she said" joke!
Power outlet not working PNW FRS Issues | Warranty | Recalls / TSB 31 01-29-2017 12:59 PM
FS: Itronics ITV-80 Uninterupted Power 12V outlet Tim_Asphalt_FRS Audio/Visual, Electronics, Infotainment, NAV 10 09-18-2013 02:53 AM
Power outlet fuse Kev01 AFRICA 5 03-04-2013 11:41 PM
Glove compartment power outlet Trojan_SC Electronics | Audio | NAV | Infotainment 7 08-02-2012 09:47 PM
