Old 06-06-2016, 03:02 PM   #1
DemonRawr
Drives: 2014 BRZ Limited 6M
Power Outlet in Center Console not Working (Not a Blown Fuse)
The outlet in the glovebox works fine, but the center console outlet does not work. I've checked the fuse as suggested by other posts regarding this issues, but there was no sign of a blown fuse. I still swapped it with a new fuse, but no dice. Any one got this fixed?
DemonRawr is offline   Reply With Quote
Old 06-06-2016, 03:23 PM   #2
Was your console or shifter ever apart? Maybe the wires have just come unclipped.
Old 06-06-2016, 03:53 PM   #3
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Probably right, remove center console and secure all wire/clips, than test the outlet before you put back everything! Bam mission complete lol
Edit:lol using swipe on tablet is a bit to get used to
turtlefeeder is offline   Reply With Quote
Old 06-06-2016, 04:14 PM   #4
extrashaky
Originally Posted by turtlefeeder View Post
Probably right, remove center console and secure all write, than test the outlet before you put ball everything!
Put ball everything? Do not taunt happy fun ball! Secure all write, than monkey apple carburetor.
Power outlet not working PNW FRS Issues | Warranty | Recalls / TSB 31 01-29-2017 12:59 PM
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Power Outlet Is Not Working Oakhenshield Scion FR-S / Toyota 86 GT86 General Forum 11 01-01-2015 07:41 PM
Power outlet fuse Kev01 AFRICA 5 03-04-2013 11:41 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 09:56 AM
