Old 03-23-2013, 08:07 PM   #1
PNW FRS
PNW FRS's Avatar
Power outlet not working
The one by the cup holder. Checked the fuse... it is not blown...
Any thoughts on troubleshooting?
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 03-24-2013, 03:04 AM   #2
DChan415
www.TheGarageSF.com
Drives: 13 BRZ
Not all accessory plugs fit all outlets. Sometimes the shape of the plug just doesn't allow for a good contact. Honda had a tsb and redesigned some power outlets for that reason. Check for power with a different accessory and see if there really is power there. Otherwise, take advantage of that 3 year/36k warranty.
DChan415 is offline   Reply With Quote
Old 03-24-2013, 03:17 AM   #3
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Make sure nothing fell inside. Had this problem with my dads jetta he dropped a screw in it.....
SubaSteve is offline   Reply With Quote
Old 03-24-2013, 05:09 AM   #4
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Does this one need to have the key 'on' to work? Some don't but most do today. Don't use them myself so I don't know and didn't bother to check the manual. And have you spliced into the wiring for something aftermarket? Just thinking out loud...
Anyway, if all is correct, use the warranty...
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 03-24-2013, 11:30 AM   #5
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
havin the same issue and i still cant figure it out. i checked fuses and nothing is blown and ive been using the same plugs and all of the sudden the car does not want to start
brichard0625 is offline   Reply With Quote
Old 03-24-2013, 11:43 AM   #6
PNW FRS
PNW FRS's Avatar
Yes, car is on... The engine is on... Plug (outlet) s/b hot... the power adaptor works in my other car... so it's working... time to vist the dealer...
2013 Asphalt / MT
Olympia, Washington
Old 02-10-2014, 03:16 PM   #7
Asian Delight
Drives: Scion Fr-s 2013
I know this is old, but i have this problem, how was it fixed?
Asian Delight is offline   Reply With Quote
Old 02-10-2014, 03:27 PM   #8
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
Test it with a test light just to make sure. Careful not to short it out. Also check the one in the glove box and see if that one is working. Don't just visually inspect the fuse, pull it and check for continuity.
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
Old 02-10-2014, 03:32 PM   #9
PhreshhWun
PhreshhWun's Avatar
Drives: 2013 Subaru Brz Sport-Tech SWP
I have this same issue .. never got around to checking the fuse yet due to the cold weather. But the glove box usb port is still working fine.
I noticed when I had my charger plugged in to the center console cigarette lighter one day and I started the car, my phone got a quick charge and then the cigarette lighter cut out and no power was given after that ...
Mods: 2013 Subaru Outback fog lights, HID fog lights, LED vanity lights, LED dome light, LED trunk light, LED license plate lights, LED door courtesy lights, LED side markers, HID headlights, J2 Engineering test pipe, HKS Drop-In air filter, Window Visors, De-badged, and Diode Dynamics LED side mirrors
Side Chick: 93' 240sx Convertible
PhreshhWun is offline   Reply With Quote
Old 02-10-2014, 04:32 PM   #10
HapaHaole
Drives: Grocery cart
There is 2 fuses, one for each of the power outlets, did you check them both? Should be labeled P/POINT NO.1 and P/POINT NO.2 both 15A fuse. They are in the interior fuse box.
HapaHaole is offline   Reply With Quote
The Following 2 Users Say Thank You to HapaHaole For This Useful Post:
hmong337 (08-14-2016), jcw99 (12-26-2016)
Old 02-10-2014, 07:15 PM   #11
PNW FRS
PNW FRS's Avatar
They claim it was a fuse. Dunno for sure... I checked the fuse box before going to the dealer... but maybe it was a case of a bad fuse that "looked ok" and once replaced... solved the problem.
2013 Asphalt / MT
Olympia, Washington
The Following User Says Thank You to PNW FRS For This Useful Post:
Asian Delight (02-10-2014)
Old 02-10-2014, 08:05 PM   #12
Asian Delight
Sweet. Did they tell which exact fuse?
Sent from my SPH-L720 using Tapatalk
Old 02-10-2014, 11:28 PM   #13
PNW FRS
PNW FRS's Avatar
Sorry... I don't recall...
I suspect it is the one designated for the AUX outlets... consult Owner's Manual for the appropriate # slot.
2013 Asphalt / MT
Olympia, Washington
Old 02-10-2014, 11:39 PM   #14
HapaHaole
which box did you check?
Toyota Parts Outlet Gen User/Vendor/Sponsor Reviews, Feedback, Comments 13 09-22-2013 12:16 PM
Power outlet fuse Kev01 AFRICA 5 03-04-2013 11:41 PM
USB Outlet?? Ben_G CANADA 16 01-30-2013 02:13 AM
Glove compartment power outlet Trojan_SC Electronics | Audio | NAV | Infotainment 7 08-02-2012 09:47 PM
