Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-07-2021, 07:34 PM   #99
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Baldeagle View Post
Caveat emptor.
Hehe, well I should clarify - id expect honesty about certain things.
A spec sheet is a spec sheet right. Some variation might exist, but how far until it breaches advertising laws?
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
Baldeagle (09-08-2021)
Old 09-08-2021, 08:53 AM   #100
Baldeagle
Drives: VW GLI 6MT
You are 100% correct that Subaru and Toyota purport facts. No lies told. But by emphasizing “peak torque now occurs at 3,700 rpm” without full context, is marketing exploiting that fact to help us infer the torque dip is nearly gone when it appears it is not. It is still a Bactrin Camel torque curve, only with the first hump now being just a tiny bit higher than the second hump. A spec sheet doesn’t convey that information.
The smoother graph of the torque-curve on the dashboard doesn’t help either. If future dynos confirm these two initial dynos are correct, must the dashboard graph be to perfect scale? The 1st gen Twin displayed that dip to proper scale. Why doesn’t the 2nd gen Twin do the same? Again, that assumes these two dynos are correct.
For me, I just want to know if it is irritating in daily driving. I imagine that like nearly all of us on the forum, we now know to pay special attention to this when we test drive it, see how it suits our preferences. For the record, I’m still excited to drive it!
Baldeagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Baldeagle For This Useful Post:
Blighty (09-08-2021), Ohio Enthusiast (09-08-2021)
Old 09-08-2021, 09:06 AM   #101
Ohio Enthusiast
Drives: 2018 BRZ
My take is that the gen 1 engine power complaints reached a meme level very early on, where facts don't matter and every reporter has to mention how terrible it feels to floor it at 5th gear going 50 MPH (looking at you, Everyday Driver). It makes me wonder how it would have played out if Subaru tuned the FA20 to have the first torque hump higher than the second like in the FA24...
The marketing for the FA24 had to "solve" the FA20's "issue", and the easiest is to raise the first hump and lower the second hump to give the on-paper benefit of peak torque arriving earlier.
At the end of the day, peak HP and torque figures are the very beginning of comparing two engines. The RPM at which these peaks occur is the next step, and a full dyno chart is very helpful (especially if you already drove different engines with different "types" of dyno charts and know what to expect in the driving experience). But most people don't really do that (or know or care), hence the HP wars, and most journalists take marketing material at face value and build a narrative off of that (I'm sure a lot of the gen 2 reviews would have been different if the second hump would have remained higher and on-paper you still would get a "peaky torque").
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Baldeagle (09-08-2021), Blighty (09-08-2021), timurrrr (09-08-2021)
Old 09-08-2021, 09:11 AM   #102
Pete
Pete's Avatar
Drives: 22 BRZ
They keep saying the peak torque is 3700 rpm. It is clearly not. It is closer to 3200rpm on the dyno charts we have seen. 3700 rpm is halfway down the dip.
If that's not a lie what would you call it?
That is really the important factor here, and so far I am trusting the reviewers when they say it is not annoying. I suppose I won't really know for certain until November.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete For This Useful Post:
Old 09-08-2021, 09:44 AM   #103
Blighty
Just on that Dyno.
I'm really not sure if its a good idea to take a 18km engine and just hit the dyno. That car isnt broken in. A bit of that will be truck on and off and low speed stuff, not for any length of time.
I'm not saying you need to drive it or load it up for 1000km, but certainly a few hours to allow those honing marks on the cylinder to come off and the other bits and pieces to seat right.
Pete (09-08-2021)
Old 09-08-2021, 09:49 AM   #104
Pete
Pete's Avatar
Drives: 22 BRZ
Just on that Dyno.
That is true. As an anecdotal example, Matt Farah said a few times that his Focus RS picked up a lot of power after the break in period.
Maybe the mid range torque will get better after some miles are on the engine? I'd be good with that.
But I hear your point that these results are still very early and we shouldn't put too much weight on the literal first dyno chart we've ever seen.
The Following 3 Users Say Thank You to Pete For This Useful Post:
Blighty (09-08-2021), DriveDriftDogfight86 (10-03-2021), timurrrr (09-08-2021)
Old 09-08-2021, 09:56 AM   #105
Baldeagle
Drives: VW GLI 6MT
And that large discrepancy gives me reason to question those two dynos. Could they be inaccurate? Rarely does the shape of a stock torque curve deviate from the manufacture's claims. Peak values, yes. Location of those peaks, not so much. Hopefully we can see other dynos for confirmation.
Blighty (09-08-2021), Pete (09-08-2021)
Old 09-08-2021, 10:34 AM   #106
Baldeagle
Drives: VW GLI 6MT
I have NO idea where this person obtained his info. But at 4:37 into the video he states:
“Yes it still has a torque dip, but instead of losing more than 15 pound feet, it loses five, and over a much smaller rev range.”
If we divide 5 lbs-ft by 184 lbs-ft, we get a 2.7% decrease, not the 15% reflected by the two dynos. And to those with a keen eye, at what rpm does the torque peak on the 2.4’s graph? Looks about 3,500 rpm to me. If we assume this graph came from Subaru (and that may be foolish), why would Subaru’s graph show a peak at 3,500 rpm if Subaru’s claims the peak occurs at 3,700? Or am I getting too nit-picky?
The Following User Says Thank You to Baldeagle For This Useful Post:
Old 09-08-2021, 10:39 AM   #107
Pete
Pete's Avatar
Drives: 22 BRZ
He got those numbers and graph from the dashboard display on the new car. That graph is exactly why we were disappointed when the actual dyno chart came out.
But, like you have said, the dyno graph we have seen is early and we should wait for more data before making judgements.
The Following 4 Users Say Thank You to Pete For This Useful Post:
Baldeagle (09-08-2021), Blighty (09-08-2021), timurrrr (09-08-2021), ZDan (09-08-2021)
Old 09-08-2021, 10:53 AM   #108
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Really? Because I'm not sure I've seen many, if any, dyno's of the first gen that matched up to the torque curve claimed on the dash. Surely they were all "close" I guess, and they represented the torque dip the dash displayed. But in terms of peak value locations? Just google stock brz dyno and notice that they all peak shortly before 3k and shortly before 5k RPM. That's pretty far off from the advertised curve the manufacturers have always claimed with a peak at 6400 RPM. On top of that, the manufacturers have made the torque curve look like it is always on the rise up to those RPM's, which I have never seen to be the case on any actual stock dyno's.
https://i.ibb.co/j44pp8S/torque-1.png
It's just too early to be judging anything. The dyno we see speaks of general truth and displays accurate torque peaks. The torque dip still exists, smaller in RPM range, but it's there.
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Old 09-08-2021, 11:11 AM   #109
Baldeagle
Drives: VW GLI 6MT
https://www.ft86club.com/forums/showthread.php?t=27534
The link above confirms what you stated about a 1st gen twin. It also shows a meaningful difference between a 4th gear and a 5th gear run. Thanks.
Blighty (09-08-2021), Dzmitry (09-08-2021)
Old 09-08-2021, 12:44 PM   #110
Sasquachulator
Pavement Grey
You guys realize that marketing wants the biggest numbers, and the FA20 peaks at its highest value at 6400RPM.
It peaks just shy of that at its 3000 or so RPM "first peak".
I suppose the characteristic dip right after the first peak makes the engine feel a bit more torque-deprived and peaky (like a smaller displacement, higher revving engine with no torque, like a honda B16 or 2ZZ) than an engine that typically redlines at 6500rpm
Old 09-08-2021, 01:58 PM   #111
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
That. Two engines with identical peak hp and torque at identical rpms in the same car can still provide very different performance if one has an M-shaped torque curve, and the other has a П-shaped torque curve (where the two "corners" of the curves are for the peak torque and hp).
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
Dzmitry (09-08-2021), Ohio Enthusiast (09-08-2021), stilesg57 (09-09-2021)
Old 09-17-2021, 10:10 AM   #112
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Kona61 is offline   Reply With Quote
The Following 6 Users Say Thank You to Kona61 For This Useful Post:
Dzmitry (09-17-2021), JusTheG (09-20-2021), Pete (09-17-2021), slimfit (09-17-2021), Stonehorsw (09-17-2021), ZDan (09-17-2021)
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 08:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 10:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 09:01 PM
