#100 | |
Drives: VW GLI 6MT
The smoother graph of the torque-curve on the dashboard doesn’t help either. If future dynos confirm these two initial dynos are correct, must the dashboard graph be to perfect scale? The 1st gen Twin displayed that dip to proper scale. Why doesn’t the 2nd gen Twin do the same? Again, that assumes these two dynos are correct. For me, I just want to know if it is irritating in daily driving. I imagine that like nearly all of us on the forum, we now know to pay special attention to this when we test drive it, see how it suits our preferences. For the record, I’m still excited to drive it! |
| The Following 2 Users Say Thank You to Baldeagle For This Useful Post: | Blighty (09-08-2021), Ohio Enthusiast (09-08-2021) |
#101 | |
Drives: 2018 BRZ
The marketing for the FA24 had to "solve" the FA20's "issue", and the easiest is to raise the first hump and lower the second hump to give the on-paper benefit of peak torque arriving earlier. At the end of the day, peak HP and torque figures are the very beginning of comparing two engines. The RPM at which these peaks occur is the next step, and a full dyno chart is very helpful (especially if you already drove different engines with different "types" of dyno charts and know what to expect in the driving experience). But most people don't really do that (or know or care), hence the HP wars, and most journalists take marketing material at face value and build a narrative off of that (I'm sure a lot of the gen 2 reviews would have been different if the second hump would have remained higher and on-paper you still would get a "peaky torque"). |
#102 | |
Drives: 22 BRZ
If that's not a lie what would you call it? That is really the important factor here, and so far I am trusting the reviewers when they say it is not annoying. I suppose I won't really know for certain until November.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
#103 |
Drives: WR Blue Pearl 2022 Subaru BRZ
Just on that Dyno.
I'm really not sure if its a good idea to take a 18km engine and just hit the dyno. That car isnt broken in. A bit of that will be truck on and off and low speed stuff, not for any length of time. I'm not saying you need to drive it or load it up for 1000km, but certainly a few hours to allow those honing marks on the cylinder to come off and the other bits and pieces to seat right. |
| The Following User Says Thank You to Blighty For This Useful Post: | Pete (09-08-2021) |
#104 | |
Drives: 22 BRZ
Maybe the mid range torque will get better after some miles are on the engine? I'd be good with that. But I hear your point that these results are still very early and we shouldn't put too much weight on the literal first dyno chart we've ever seen.
| The Following 3 Users Say Thank You to Pete For This Useful Post: |
#105 |
Drives: VW GLI 6MT
And that large discrepancy gives me reason to question those two dynos. Could they be inaccurate? Rarely does the shape of a stock torque curve deviate from the manufacture's claims. Peak values, yes. Location of those peaks, not so much. Hopefully we can see other dynos for confirmation.
#106 |
Drives: VW GLI 6MT
I have NO idea where this person obtained his info. But at 4:37 into the video he states: “Yes it still has a torque dip, but instead of losing more than 15 pound feet, it loses five, and over a much smaller rev range.” If we divide 5 lbs-ft by 184 lbs-ft, we get a 2.7% decrease, not the 15% reflected by the two dynos. And to those with a keen eye, at what rpm does the torque peak on the 2.4’s graph? Looks about 3,500 rpm to me. If we assume this graph came from Subaru (and that may be foolish), why would Subaru’s graph show a peak at 3,500 rpm if Subaru’s claims the peak occurs at 3,700? Or am I getting too nit-picky? |
| The Following User Says Thank You to Baldeagle For This Useful Post: | Blighty (09-08-2021) |
#107 |
Drives: 22 BRZ
He got those numbers and graph from the dashboard display on the new car. That graph is exactly why we were disappointed when the actual dyno chart came out.
But, like you have said, the dyno graph we have seen is early and we should wait for more data before making judgements.
#108 | |
Drives: 2018 Subaru BRZ Limited with PP
https://i.ibb.co/j44pp8S/torque-1.png It's just too early to be judging anything. The dyno we see speaks of general truth and displays accurate torque peaks. The torque dip still exists, smaller in RPM range, but it's there. |
#109 | |
Drives: VW GLI 6MT
The link above confirms what you stated about a 1st gen twin. It also shows a meaningful difference between a 4th gear and a 5th gear run. Thanks. |
#110 |
Pavement Grey
You guys realize that marketing wants the biggest numbers, and the FA20 peaks at its highest value at 6400RPM.
It peaks just shy of that at its 3000 or so RPM "first peak". I suppose the characteristic dip right after the first peak makes the engine feel a bit more torque-deprived and peaky (like a smaller displacement, higher revving engine with no torque, like a honda B16 or 2ZZ) than an engine that typically redlines at 6500rpm |
#111 | |
Drives: 2022 GR86
| The Following 3 Users Say Thank You to timurrrr For This Useful Post: |
#112 |
Drives: ‘22 CWP
| Typical Mustang Dyno Numbers? | Rockz222 | Engine, Exhaust, Transmission | 6 | 07-11-2015 08:33 PM |
| Dyno numbers | ogrowup | Engine, Exhaust, Transmission | 7 | 12-27-2014 08:04 AM |
| Average Stock Dyno Numbers? | KONVERTER | Engine, Exhaust, Transmission | 23 | 10-12-2013 10:13 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| dyno numbers seem low | stealth_fighter | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-02-2013 09:01 PM |
