Old 09-02-2021, 11:39 AM   #1
SportyTaco86
SportyTaco86's Avatar
Drives: 2013 Scion FRS, 2012 Tacoma
Turn signal issue/question
I just picked up my FRS last week and noticed an issue with the turn signals right off the bat. When I first hit the switch (right or left) the indicator and signals come on but don't flash. If I turn the wheel slightly they will start flashing. This happens if the wheel is straight, or even if the wheel is already turned. Would this be a clockspring issue? Maybe the flasher relay (seems less likely)?
The PO had every cheap LED imaginable installed on the car, so I replaced all of the bulbs with OE replacements and it didn't resolve the issue.
I believe I had something similar happen with a 2004 Forester I owned a while back and there was a cup inside the steering column I had to replace.
SportyTaco86 is offline   Reply With Quote
Old 09-02-2021, 02:52 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Welcome to the forum SportyTaco86! There are a couple of third-party turn signal relay replacements that can be programmed to flash in various patterns. They are fairly common and an easy plug-and-play mod. But sometimes prone to problems. Maybe verify if you have an original factory relay or an aftermarket and is it working correctly? I agree, not as likely, but fairly easy to check.
LimitedSlip is offline   Reply With Quote
Old 09-02-2021, 03:48 PM   #3
SportyTaco86
Thanks! I'll take a look and see what I'm dealing with.
Old 09-02-2021, 03:57 PM   #4
SportyTaco86
Really good call! I looked under the dash and the OEM relay was still in place, but the harness was plugged into an LED relay that was left dangling under the column. That seems to have corrected the issue. I won't know for sure until I can take it for a spin later.
On another note, I've been dealing with a hyperflash issue on my Tacoma since installing aftermarket headlights (haven't had the time or motivation to add load equalizers), so maybe the LED relay will fit the Taco.
Old 09-02-2021, 10:33 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
according to this:
https://www.diodedynamics.com/led-fl...ta-tacoma.html
it's functionality is going to depend on if you have DTRL on your truck
looks like there's some big threads on tacomaworld on this as well
Old 09-03-2021, 08:58 AM   #6
SportyTaco86
according to this:
Thanks! I saw that as well. I do have DTRLs. Of course, the relay malfunctioning is what led to the creation of this thread, so I'll be throwing on some load equalizers instead. I'm 99% sure I have a few sets in the garage from motorcycle builds I've done in the past.
Turn signal cancelling/turn off issue Koi Issues | Warranty | Recalls / TSB 5 10-18-2020 11:19 PM
TOMs & turn signal issue Powered By Jay Cosmetic Modification (Interior/Exterior/Lighting) 19 01-15-2015 12:33 AM
OLM turn signal switchback issue Scavanger Scion FR-S / Toyota 86 GT86 General Forum 5 09-17-2014 12:42 PM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 01:47 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 07:06 PM
