Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-01-2021, 06:42 AM   #29
Lantanafrs2
Drives: 2013 frs red
Same type of dyno with same compressed graph.
Lantanafrs2 is offline   Reply With Quote
Old 09-01-2021, 07:28 AM   #30
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by drift86 View Post
I'm excited to see this torque dip. It tells me the car is still choked by the headers for emission reasons and that some catless headers + tune should make healthy gains just like the first gen.
You'd rather have to expend time/money/effort to get rid of "torque dip", than to just not have it in the stock setup?
I installed a catless header and got custom tune for my car this year due to arms race in my time-trialing class. After $$$$ and effort wriggling around under the car, while making it technically non-compliant with emissions regs, eliminated the torque dip. I would have *vastly* preferred just not having the dip in the first place!
The Following 6 Users Say Thank You to ZDan For This Useful Post:
DriveDriftDogfight86 (10-03-2021), Lantanafrs2 (09-01-2021), Pete (09-01-2021), stilesg57 (09-01-2021), timurrrr (09-01-2021), wheelspeed (09-13-2021)
Old 09-01-2021, 08:17 AM   #31
Lantanafrs2
Maybe they had the parking brake on
Old 09-01-2021, 08:22 AM   #32
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Right in that RPM range to simulate that torque dip. Such a beautiful dip it is. Some day it's going to be a legendary dip that people will appreciate when they sit in their EV and it pulls flat-even the whole way.
Dzmitry is offline   Reply With Quote
Old 09-01-2021, 08:29 AM   #33
Lantanafrs2
I dont trust that graph. I think it will look smoother on a dyno jet. I've seen some compressed charts that accentuate everything which can be great when you're selling parts.
Old 09-01-2021, 09:32 AM   #34
Dzmitry
Dzmitry's Avatar
I think it's a perfectly trustworthy graph, far more than a dyno jet will prove to be. People just hate seeing the reality of more accurate dyno's. It looks pretty identical to the first gen as I linked earlier. But a couple things to keep in mind is that the dip is not as broad in gen2 and that the overall torque is higher in gen2 - so the % loss of torque isn't as bad as it was in gen1.
The Following 3 Users Say Thank You to Dzmitry For This Useful Post:
Pete (09-01-2021), stilesg57 (09-01-2021), Vides990 (09-01-2021)
Old 09-01-2021, 10:24 AM   #35
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
I am pretty sure that's not his point. His point, I believe, is that it is evidence of the fact that a simple header change and tune (which most of us are more than willing to do given cost/value prop) will likely yield similar gains on the new car. And that is indeed good news, at least to this potential 2022+ buyer, as it means that maybe, just maybe, that car with just those simple mods will be enough for me not to yearn for FI (which is definitely somewhere I would prefer not to go).
CincyJohn is offline   Reply With Quote
The Following User Says Thank You to CincyJohn For This Useful Post:
drift86 (09-01-2021)
Old 09-01-2021, 10:44 AM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
You're repeating exactly the same point: *glad* there's a torque dip because that means you can spend time and $$$$ and effort to eradicate it (while making car illegal).
How on earth is that *better* than simply not having a torque dip (or having a more minimal one) in the 1st place?
I'd way way WAY rather see torque/power curves more similar to the graphs on the info screen we've seen...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Blighty (09-01-2021), Pete (09-01-2021), stilesg57 (09-01-2021)
Old 09-01-2021, 11:47 AM   #37
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
It will be really interesting to see more dynos.
Interesting that the values in this one suggest its lost 20% hp, and 11% tq through the drivetrain. (remember this is the 231hp JDM).
The tq peak is quite a bit earlier than the manufacturer suggest as well.
Are there any issues from dynoing it with 13kms (before its very initial break in)?
Also I wonder what car it is, its got a spacer where the head unit should be - was it a pre-prod or some kind of subaru stripper?
Blighty is offline   Reply With Quote
Old 09-01-2021, 12:47 PM   #38
austintampa
Drives: honda element
Originally Posted by PulsarBeeerz View Post
Not very as there are two examples dyno videos and multiple runs. Plus oem tunes are way more likely to run rich and safe than lean.
not when emissions is the goal.
my ecoboost mustang would ping on sudden low RPM application of throttle - I dont assume that to be a rich condition.
austintampa is offline   Reply With Quote
Old 09-01-2021, 01:24 PM   #39
Sasquachulator
Pavement Grey
Seems like Japan gets additional infotainment choices.
The blank option, a larger touch screen that takes up all the bezel, and I think theres a double-din non-integrated unit.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Old 09-01-2021, 01:26 PM   #40
Baldeagle
Drives: VW GLI 6MT
You are probably correct. That ping is probably NOT related to a rich fuel mixture. What you describe may be Low Speed Pre Ignition (LSPI).
https://www.oronite.com/about/news/l...causes-of-LSPI
“Low speed pre-ignition (LSPI) is a premature combustion event, occurring prior to spark ignition in turbocharged, downsized gasoline vehicles. As the name implies, it occurs when engines operate at low speeds and high loads. It can result in extremely high cylinder-pressures and can lead to heavy knock. At a minimum, LSPI can generate an audible knocking noise noticeable to the driver. Repeated exposure to these conditions can cause engine hardware failure, including broken spark plugs and cracked pistons
Because your Mustang is turbocharged, it is vulnerable to LSPI if you hit the gas too hard at very low rpm. However, the twin’s engine is not turbocharged. A bad driver can still lug it, but it will not get LSPI.
Baldeagle is offline   Reply With Quote
The Following User Says Thank You to Baldeagle For This Useful Post:
OkieSnuffBox (09-01-2021)
Old 09-01-2021, 05:23 PM   #41
FlyingJett
Drives: Scion frs
Xmm.. is it a right time to look at GR Yaris ?)
FlyingJett is offline   Reply With Quote
Old 09-01-2021, 06:30 PM   #42
drift86
Drives: GT86, 22 BRZ
From all the driving reports on the new car, the torque dip cannot be felt anymore. Unlike the first car, you don't need to spend any money to "get rid" of it if you are happy with stock levels of power.
For those that want to get a bit more power out of the car, the familiar looking torque dip tells me the new car will potentially respond to mods in a similar way as the first gen. 10-15% gains with a simple header, tune and e85 is amazing gains for a NA car. One of the best mods I have made on any car I've owned.
I'm sure Toyota/Subaru will prefer not to have a torque dip at all. But for cold start emission reasons, they likely had to position the cat as close to the engine as possible which compromises the exhaust flow.
drift86 is offline   Reply With Quote
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 08:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 10:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 09:01 PM
