Drives: 2015 Subaru BRZ WRB
Retorqing the head bolts.
* EDIT for people searching in the future *
Depending on the manufacturer of head gasket you do not need to retorque head bolts. TYPICALLY multilayer METAL head gaskets do not need to be retorqued. Almost all head gaskets for the FA20 worth getting are muti-layer metal and don't need to be retorqued. Last edited by irax; 08-30-2021 at 03:44 PM. |
| The Following User Says Thank You to irax For This Useful Post: | humfrz (08-28-2021) |
#2 | |
Drives: Q5 + BRZ + M796
The head studs are 12 point 14mm torque to yield (TTY) bolts. Some say it isn’t good to re-torque TTY bolts multiple times, while others say it is fine. Just saying.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | soundman98 (08-28-2021) |
#3 |
So, to retorque the heads I need to remove the timing cover, the timing tensioners, the timing chains, the the cam girdle carrier with cam and retainers as one piece, retorque the heads, re assemble, re set the timing? I just want to make sure there is no other way around it.
#4 | |
#6 | |
![]() Back in the day, when rebuilding an engine, we used to torque the head bolts down "on the way out" of the rebuild. NOT after the job was done - ![]() Yep, torque the head bolts down, adjust the valves, replace the valve cover then crank that puppy up - ![]()
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (08-29-2021), Tokay444 (08-30-2021) |
#7 | |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | humfrz (08-28-2021) |
#8 |
#9 |
#10 |
Drives: 2013 frs base
Am I reading this correctly? I have never heard of anybody re torquing subbie heads after a rebuild. Can you even access to the bolts with engine in the car? Not to mention, to get the cams out, you would have to take apart the timing cover, then retime the engine and reset the lash of all 16 valves.
| The Following User Says Thank You to blsfrs For This Useful Post: | humfrz (08-31-2021) |
#11 | |
Maybe follow this, but I could have sworn I saw something where someone removed the cams or something without pulling off the timing cover. https://www.ft86club.com/forums/showthread.php?t=103339
#12 | |
#13 | |
Definitely, wait for word from maker of the head gaskets before proceeding. |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | irax (08-29-2021), soundman98 (08-29-2021) |
#14 | |
| Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 11:53 AM |
| OEM Camber Bolts (Crash Bolts - SU003-02818) | dieseldan444 | Brakes, Suspension, Chassis | 2 | 07-12-2018 09:06 PM |
| ARP rod bolts | Grip Ronin | Engine, Exhaust, Transmission | 6 | 09-10-2015 10:22 AM |
| 86 with bolts on ! Like the BRZ TS | asnoir | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-12-2014 05:14 PM |
| Camber bolts | Kosmos | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 05-08-2014 11:15 PM |
