Old 09-09-2015, 09:54 AM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
ARP rod bolts
Does anyone know if you can swap in rod bolts with just an oil pan removal?
IG-Joey_Soul
Old 09-09-2015, 02:46 PM   #2
seant2h
Drives: 2013 BRZ 6MT LTD
Yes, you should be able to replace the connecting rod bolts if you remove both the upper and lower oil pan since the bolts are at an angle. I have a FA20 down the short block right now if you want me to post a picture of what you will encounter when removing the oil pans.
Also, take a look at the pictures in this link where they rebuild this motor and you will see how the rod bolts are at an angle and not parallel to the connecting rod shaft.
http://www.revvolution.com/blog/2014...he-fa20-4u-gse
seant2h is offline   Reply With Quote
Old 09-09-2015, 03:41 PM   #3
celek
Resident Gear Head
celek's Avatar
Not worth it the rod bolts are not a weak link the rod is
celek is offline   Reply With Quote
Old 09-10-2015, 01:53 AM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ive read thru that link before but yea if you have a pic that'd be good just to know what im up against since i will be removing the lower pan anyway for an oil return.
IG-Joey_Soul
Old 09-10-2015, 01:57 AM   #5
Grip Ronin
The Mechanic
Grip Ronin's Avatar
yes i've read up on a few people blowing motors but it doesnt hurt to try old ideas. ive made 408whp on my basiclly stock honda gsr for over 50k miles, revving 9200 rpm and daily driven with only rod bolts, head bolts and double valve springs so i have a bit of faith in trying them. worst that happens is id shoot a rod as i would have stock or i bring something new to the forum.
IG-Joey_Soul
Old 09-10-2015, 08:52 AM   #6
celek
Resident Gear Head
celek's Avatar
The necks of the rods twist under the wrist pin that's the failure with stock rod bolt people have gotten to 500WHP but the rods are weak at that point.
12.5:1 compression and knock/detonation bends rods.
But to answer your question yes you can access the rods/bolts through the bottom
Old 09-10-2015, 10:22 AM   #7
Grip Ronin
The Mechanic
Grip Ronin's Avatar
oh i didnt see that post lol well im going to hang around 300 but that doesnt mean the rods cant bend. thanks for the info ill look into that more.
IG-Joey_Soul
FS: SPC Camber Bolts bottle Canada Classifieds 0 07-12-2015 06:45 PM
86 with bolts on ! Like the BRZ TS asnoir Scion FR-S / Toyota 86 GT86 General Forum 1 08-12-2014 05:14 PM
Tial BOV bolts Sportsguy83 Forced Induction 6 04-14-2014 01:49 PM
WTB Camber Bolts JS + BRZ Want-To-Buy Requests 6 03-07-2014 07:18 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
