Old 05-04-2014, 11:27 PM   #1
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Camber bolts
So I looked at the instructions for the camber bolts I purchased.... is this right? from my experiences and from what I always was showed. Was to replace the upper strut bolt not the lower.. Name:  uploadfromtaptalk1399256861493.jpg
Sent from my SM-N900P using Tapatalk
Kosmos is offline   Reply With Quote
Old 05-05-2014, 08:55 PM   #2
Wyattkb
Drives: 2014 Whiteout FRS
My whiteline bolts said to use the top bolt hole unless its a race application.
So I used the top holes.
Wyattkb is offline   Reply With Quote
Old 05-05-2014, 08:57 PM   #3
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
I already figured it out. You can do both top or bottom bolts
Old 05-05-2014, 09:25 PM   #4
Wyattkb
Changing the bottom bolts has a different final outcome for alignment specs.
You can also replace top and bottom bolts for more adjustment.
Old 05-05-2014, 11:39 PM   #5
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
I did the tops only using the same product under different brandname... it dramatically affected handling; turn-in response is quicker, the car is more twitchy, more alive.
Be careful of unevenly banked roads at high speeds. I couldn't imagine any more for a daily, but that's just me.
hamzam is offline   Reply With Quote
Old 05-06-2014, 12:42 AM   #6
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
The tops are called crash bolts I believe. And they are popular. I will probably get some to get more camber to tuck my wheels
Old 05-08-2014, 11:43 PM   #7
tyler_win_photo
tyler_win_photo's Avatar
Usually if you replace the lower bolt, you'll get more camber than if you were to replace the top. Many people suggest to replace only the top, as the bottom bolt has a lot of stress on it, and shouldn't be altered especially by a smaller bolt because it will be weaker. You can also replace both the top and bottom bolt to get around 2.3 degrees negative camber, but people have found that after some hard driving your camber settings could be way off from what you started at.
All in all, if you want to be safe, just replace the top. If you need more camber than what the top bolts can offer you, get camber plates.
tyler_win_photo is offline   Reply With Quote
Old 05-09-2014, 12:15 AM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
14mm goes in the bottom. 16mm goes in the top. This is with lobed bolts. The oem crash bolts are 14mm and go in the top slot.
WTB Camber Bolts JS + BRZ Want-To-Buy Requests 6 03-07-2014 08:18 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 10:00 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
