Old 08-27-2021, 09:32 AM   #1
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Retorqing the head bolts.
* EDIT for people searching in the future *
Depending on the manufacturer of head gasket you do not need to retorque head bolts.
TYPICALLY multilayer METAL head gaskets do not need to be retorqued.
Almost all head gaskets for the FA20 worth getting are muti-layer metal and don't need to be retorqued.
irax is offline   Reply With Quote
The Following User Says Thank You to irax For This Useful Post:
humfrz (08-28-2021)
Old 08-28-2021, 01:08 AM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by irax View Post
I tried searching for an answer to this and I couldn't find anything.
But I wanted to double check, is the only way to retorque the head bolts is by removing the cams and cam girdles ? It doesn't look like there is enough room to get a crows foot in there otherwise.
There is a valve cover, cam retainers and a cam girdle/carrier, and then the heads that have the valves, rockers and spring assemblies. I think once you remove the valve cover you can remove the whole cam assembly to get to the head studs, but I don’t think you can get to the head studs without removing the carrier. I don’t think you need to remove the cam retainers separately. Just remove the whole upper and lower cam assembly as one piece. I think you will be removing some 12mm bolts to remove the entire cam assembly. If you remove the 10mm bolts then you will be removing the cam retainers and the cam shafts will come out separately from the cam carrier, and you still won’t have access to the head studs.
The head studs are 12 point 14mm torque to yield (TTY) bolts. Some say it isn’t good to re-torque TTY bolts multiple times, while others say it is fine. Just saying.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
soundman98 (08-28-2021)
Old 08-28-2021, 02:01 AM   #3
irax
irax's Avatar
So, to retorque the heads I need to remove the timing cover, the timing tensioners, the timing chains, the the cam girdle carrier with cam and retainers as one piece, retorque the heads, re assemble, re set the timing? I just want to make sure there is no other way around it.
Old 08-28-2021, 02:55 AM   #4
I must ask (sorry) - why do you want to retorque the head bolts?
Old 08-28-2021, 10:22 AM   #5
irax
irax's Avatar
You need to retorque the head bolts after assembling the motor after rebuild.
humfrz (08-28-2021)
Old 08-28-2021, 03:35 PM   #6
Oh, I reckon I'm behind -
Back in the day, when rebuilding an engine, we used to torque the head bolts down "on the way out" of the rebuild. NOT after the job was done -
Yep, torque the head bolts down, adjust the valves, replace the valve cover then crank that puppy up -
soundman98 (08-29-2021), Tokay444 (08-30-2021)
Old 08-28-2021, 04:02 PM   #7
Irace86.2.0
He might mean after breaking the engine in.
humfrz (08-28-2021)
Old 08-28-2021, 04:08 PM   #8
Ahhhh ....... OK.
Old 08-28-2021, 04:15 PM   #9
irax
irax's Avatar
Exactly!
Old 08-28-2021, 05:16 PM   #10
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Am I reading this correctly? I have never heard of anybody re torquing subbie heads after a rebuild. Can you even access to the bolts with engine in the car? Not to mention, to get the cams out, you would have to take apart the timing cover, then retime the engine and reset the lash of all 16 valves.
The Following User Says Thank You to blsfrs For This Useful Post:
humfrz (08-31-2021)
Old 08-28-2021, 07:14 PM   #11
Irace86.2.0
Are you pulling the motor?
Maybe follow this, but I could have sworn I saw something where someone removed the cams or something without pulling off the timing cover.
https://www.ft86club.com/forums/showthread.php?t=103339
Old 08-28-2021, 08:03 PM   #12
irax
irax's Avatar
With other engines you retorque the headbolts after the first heat cycle. I have emailed the maker of the headgaskets to see if its something they recommend for their product but I have yet to get an email back.
Old 08-29-2021, 09:38 AM   #13
blsfrs
blsfrs's Avatar
A several years ago the EJ205 in my 2000 Impreza blew a head gasket. I had a local subbie guy plane the heads and reassemble the engine. No re torquing was recommended. A couple of years ago I had an FA20 built by Element Tuning. Again, no re torquing recommended.
Definitely, wait for word from maker of the head gaskets before proceeding.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
irax (08-29-2021), soundman98 (08-29-2021)
Old 08-29-2021, 04:24 PM   #14
irax
irax's Avatar
Yeah this is the first subie engine that I have had rebuilt so hopefully this thread will others in the future as well.
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
ARP rod bolts Grip Ronin Engine, Exhaust, Transmission 6 09-10-2015 10:22 AM
86 with bolts on ! Like the BRZ TS asnoir Scion FR-S / Toyota 86 GT86 General Forum 1 08-12-2014 05:14 PM
Camber bolts Kosmos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-08-2014 11:15 PM
