Old 08-03-2020, 08:21 AM   #1
Ciallise
Drives: 2013 BRZ limited
Subaru BRZ 2013 ABS and traction control lights / C1231
Hey,
First post here, long time lurker. I have been scouting previous threads for 1 month now and I am not able to figure out why I am having ABS and traction control light on, so I thought maybe someone has fought with the same problem. Dealer wont help me since car is in EU and is US spec. So:
I bought 2013 BRZ from salvage auctions (IAAI / US) late 2019, front damaged and imported it to EU. Seatbelts and airbags were blown (including steering wheel). Clock spring --> airbag connectors had melted, so I ordered new clock spring.
After replacing airbags, seatbelts and resetting SRS module I got error C1231 whitch means steering angle sensor short. I bought new steering angle sensor and same error stays (if I remove it I get different code). I have Techstream and I tried to do the zero point calibration (or something like that), but no help. Code disappears but as soon as I turn steering wheel it comes back.
Any help / suggestions are welcome since I have been battling with this for 3 months now
Ciallise is offline   Reply With Quote
Old 08-03-2020, 12:21 PM   #2
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Where was the car hit? Front drivers side? Is that the only code?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-03-2020, 12:34 PM   #3
Ciallise
Car was hit the middle. Beam in the front was bend and rails going to that were bend little bit. Bodyshop fixed it. No other codes.
https://gyazo.com/909421c794cdb37a7a64a6c3b8700a37 Link for picture
Last edited by Ciallise; 08-03-2020 at 12:36 PM. Reason: Pic didin't show in original post so added link
Old 08-03-2020, 01:41 PM   #4
Opie
Opie's Avatar
If the steering angel sensor is new the code would indicate a wiring/contact issue.
Check where the harness plugs into the ABS pump (front left/drivers) and make sure it is secure and there are no damaged wires.
Check the plug that plugs into the steering angle sensor, be sure when the clock spring wires melted it didn't damage those.
On the steering angle sensor check the harness
Check the voltage between terminals.
Voltage
Inspection terminals: D56-4(IG) - chassis ground
Inspection conditions: IG ON
Standard value: 11 to 14 V
Check the resistance between terminals.
Inspection terminals: D56-1(ESS) - chassis ground
Inspection conditions: Always
Standard value: Less than 1 Ω
If the values aren't correct, there is a issue in the harness.
Old 08-03-2020, 03:37 PM   #5
Ciallise
4th pin was 12.4v and pin 1 0.65 ohms. Connector on the abs is tight and no visible damage. Nothing had to be changed on drivers corner so I don't think it is at the abs pump.
Sadly i didin't try to drive / turn on the car before I changed the clockspring / airbags so I don't know if the car came with the problem or no. Could it be that I just had broken one and bough another broken one? The one I bought was used.
Old 08-04-2020, 06:25 AM   #6
Ciallise
Also I went through all the fuses and everything is ok (both in dash and the engine bay).
Old 08-04-2020, 10:10 AM   #7
Ciallise
Original part (which came with the car) had number 27546CA000, so I bough new with the same parts number. Now when I did more research I found out that this is FRS / GT86 part. When searching for BRZ steering angle sensor I found 27549CA000 / 27549CA001. Does anyone know if the FRS sensor should work fine in the BRZ ?
Old 08-05-2020, 02:40 PM   #8
Ciallise
Update: When I do the VSC reset I can remove the error. After removing the error and going to live data in techstream i can see angle sensor sending data fin from +360 to -360, but when going past 1 turn it gets stuck and wont recover / start sending data again.
Old 06-25-2021, 02:49 AM   #9
alepar
Drives: BRZ '14
Any chance you were able to solve this? I'm struggling with exactly the same problem...
alepar is offline   Reply With Quote
Old 06-28-2021, 04:46 AM   #10
Ciallise
I took the car to Subaru and they triend to pair sensor. They were able to do it but once again after sprinning wheel for 360 degrees sensor gets stuck. I had to buy another original subaru part (i think it was 400$ from US). After installing it it paired fine and code has never appered since. I bought FRS /GT86 part (used from ebay) but that was just waste of 200$... FRS / GT86 part might work for you but for me it didint work.
Old 07-06-2021, 05:43 PM   #11
alepar
Drives: BRZ '14
Thanks! Yeah, replacing the sensor with a new one from a dealer fixed it for me as well.
The sensor I had to replace was actually my original one, which apparently got broken when I tore my clockspring. Seems like this might be just a generic symptom of a dead sensor.
Old 02-28-2025, 05:34 PM   #12
alfakarl
Drives: 2013 Scion FR-S & Subaru BRZ
Can someone take a pick of connector D56?
alfakarl is offline   Reply With Quote
brz, c1231
Traction Control and ABS 2013 BRZ BRZ-GT86 Issues | Warranty | Recalls / TSB 2 05-29-2020 05:30 AM
ABS & Traction Control lights are on B-R-Z Issues | Warranty | Recalls / TSB 4 11-03-2017 08:27 PM
traction control and abs lights coming on after 20mins? UnLeasHer AUSTRALIA 28 02-23-2015 10:52 AM
Random traction control and ABS lights? Mr Kirmudget Scion FR-S / Toyota 86 GT86 General Forum 13 01-28-2015 12:36 PM
CEL/Traction Control Lights artizhay Issues | Warranty | Recalls / TSB 5 11-04-2012 11:33 PM
