Old 07-28-2012, 08:10 AM   #29
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by arghx7 View Post
How was the piston bowl designed on these Wiseco parts?
These design is subaru w/ slight modification of height to lower compression.
Don@Accelerated is offline   Reply With Quote
Old 07-28-2012, 01:16 PM   #30
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Originally Posted by noAE86 View Post
FA20 is direct port and direct cylinder injection,
hence the reason for the piston top, if design is correct then piston cooling should be pretty even from the direct cylinder injection,
to solve the hot spot problem in the 20valve was only a matter of ceramic coating the top, we did this to our unlimited class racer,
don: do you think these pistons will need any coating on them?
I still would like to see a heat test that shows thermal heat within the cylinder.
I would feel better if the piston was coated even if its direct port
20valvewynn83 is offline   Reply With Quote
Old 07-28-2012, 01:57 PM   #31
UncleFester
Originally Posted by Don@Accelerated View Post
By the time we throw E85 into the mix. I bet the rods will be a limiting factor!
Are you working on getting rods made as well?
UncleFester is offline   Reply With Quote
Old 07-28-2012, 02:40 PM   #32
Calum
That Guy
Drives: 2013 asphalt FRS MT
Don, are the OEM pistons floating or pressed wrist pin?
Old 07-28-2012, 03:22 PM   #33
xwd
I believe all of the horizontally opposed Subarus use floating wrist pins. The pistons are installed in the block after the rods/crank are already assembled in the case so it would be a little difficult to press a pin in there.
Old 07-28-2012, 11:33 PM   #34
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
dunno if this has been seen before but from what i see in this video looks like normal pistons to me compared to the direct injection 2gr-fse pistons....correct me if im wrong? cause from what i understood the pistons had to be designed a certain way to allow efficient combustion with the direct and port injection like the one rendered on page one...?
right after the 1 minute mark.....ohhh even better its right there in the pic! lol
[ame="http://www.youtube.com/watch?v=g5u2wPplBdY"]2013 Subaru BRZ at the Montreal Auto Show - YouTube[/ame]
mastertech86 is offline   Reply With Quote
Old 07-29-2012, 08:57 AM   #35
noAE86
Drives: ae86, etc..
yes i agree with you there, the more safe guards the better,
noAE86 is offline   Reply With Quote
Old 07-29-2012, 09:36 AM   #36
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Sounds great Don, appreciate you keepng us updated!
Don't know yet, but I would suspect pricing similar to the majority of other 4 cylinder kits.
Customs sets will be priced slightly higher.
kmbkk is offline   Reply With Quote
Old 07-29-2012, 10:15 AM   #37
Don@Accelerated
The pistons in the video are not BRZ
Old 07-29-2012, 11:47 AM   #38
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Yup, wrong rods, wrong crank, and wrong pistons. That's an EJ reciprocating assembly.
Old 07-29-2012, 12:43 PM   #39
Synack
Boosted
Synack's Avatar
Drives: Sideways
I can't wait to find out how much PSI a bone stock motor can handle.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-29-2012, 01:13 PM   #40
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I would guess around 8psi is max on this engine on pump gas. Even that would have compromises in the tune to limit detonation I believe. But perhaps the DI will prevent this?
8psi with 93 or even 100 octane could be tuned for better results. But I do wonder how well this motor can resist detonation or high temps that could melt pistons.
Coheed is offline   Reply With Quote
Old 07-29-2012, 01:16 PM   #41
Synack
Boosted
Synack's Avatar
Drives: Sideways
If so, I'll be running 6-7psi until I upgrade internals.
Old 07-29-2012, 04:55 PM   #42
Don@Accelerated
Yes. I have never seen a subaru without a floating pin. Although I have to admit, I like a challenge when assembling!
Accelerated Performance FRS/BRZ-300 Turbo Kit Don@Accelerated Forced Induction 104 11-26-2012 03:55 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 11:14 AM
