#15 | |
Thats not true at all. Our 2jz engines are 10-10.5:1 Flat top pistons. And we run 60-70psi! The compression ratio does not dictate how much power you can make! |
#16 |
#17 |
Drives: 2013 FRS/01 Tacoma
pistons are all fine and dandy but just because it lowers the compression doesn't make this safe will you guys make a heat chart of the piston when it fires and has compression in the cylinders because with the way the gas ignites the air fuel mixture this can become dangerous. i am sure you guys are all awear of this but i would really like to see some charts. One good rule of thumb is to drop compression by about one point for every 15 pounds of boost. However, keep in mind that dropping compression too far will reduce engine power when off of boost, increasing turbo lag and decreasing drive-ability. Small combustion chambers tend to do better with a deep piston dish, and larger ones do better with a shallow dish. Ideally, you want a fairly small, open combustion chamber with little to no quench (flat) area and a deeply dished piston. With the design of the top of the pistons im kind of worried about the mixture of the gas. just was hoping for a more of a semi flat style i guess.
that high spot on the piston is what im concerned about on the lower left of the picture |
#18 |
The design needs to be that way for the direct injection. Its no coincidence that the nozzle design accomodates.
| The Following User Says Thank You to Don@Accelerated For This Useful Post: | 20valvewynn83 (07-27-2012) |
#19 | |
Drives: DGM BRZ limited
Edit: got beat to the punch. Last edited by rusty959; 07-27-2012 at 05:28 PM. Reason: Got beat |
| The Following User Says Thank You to rusty959 For This Useful Post: | 20valvewynn83 (07-27-2012) |
#20 |
Drives: '06 AM V8V Coupe
Just for curiosity's sake, how much power do you think the stock pistons could hold up to, say with ethanol? 12.5 + E85 + lots of boost usually get along fine
#21 | |
with that type of design on the 20valve they were causing hot spots in the pistons |
#22 |
#23 |
#25 |
Drives: DGM BRZ Limited
I hope the rods handle 350whp without issues. I've seen stock SR20 roller-rocker/VE rods pushed to damn near 600whp before failure. 500whp stock block.
But I'd be happy with a solid 350whp reliable unopened engine, if that's possible with just a few bolt ons and bigger injectors. |
#26 | |
Drives: ae86, etc..
hence the reason for the piston top, if design is correct then piston cooling should be pretty even from the direct cylinder injection, to solve the hot spot problem in the 20valve was only a matter of ceramic coating the top, we did this to our unlimited class racer, don: do you think these pistons will need any coating on them? |
| The Following 3 Users Say Thank You to noAE86 For This Useful Post: |
#27 |
Drives: car
How was the piston bowl designed on these Wiseco parts?
#28 | |
I believe the first set will have no coatings. The production pieces will have at a minimum skirt coatings. |
| Accelerated Performance FRS/BRZ-300 Turbo Kit | Don@Accelerated | Forced Induction | 104 | 11-26-2012 03:55 AM |
| Turbo BRZ from Accelerated performance | buzznasa | BRZ First-Gen (2012+) — General Topics | 3 | 07-20-2012 11:14 AM |
