Old 05-15-2021, 09:26 PM   #1
mrhood
Drives: 2013 Scion FRS
2017 86 Header Compatible with 2013 FRS?
Hi everybody,
I need to replace the header on my 2013 FRS due to the cat failing. I am looking at replacing it with another stock header for now. I found a stock header from a 2017 86 and am wondering if these parts are interchangeable with no issues mounting. I am sort of new to these cars, so I am sorry if this has an obvious answer.
Thanks!
mrhood is offline   Reply With Quote
Old 05-15-2021, 09:51 PM   #2
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Originally Posted by mrhood View Post
Hi everybody,
Thanks!
This may help you out:
https://www.ft86club.com/forums/showthread.php?t=110818
https://www.ft86club.com/forums/showthread.php?t=111101
scion fr-s is offline   Reply With Quote
Old 05-15-2021, 11:48 PM   #3
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Welcome to the club.
This question seems easy, but they changed the flange on the 17+ models. I reckon @humfrz or @Ultramaroon knows.
The Following 2 Users Say Thank You to scion fr-s For This Useful Post:
humfrz (05-16-2021), Ultramaroon (05-16-2021)
Old 05-16-2021, 12:16 AM   #4
I'll defer to @Tcoat.
Ol @Ultramaroon don't know nutten bout loud exhausts - so, Bubba tells me -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
BrahmaBull1990 (05-23-2021), scion fr-s (05-16-2021), Ultramaroon (05-16-2021)
Old 05-16-2021, 12:36 AM   #5
DarkSunrise
DarkSunrise's Avatar
No issues. I’m using a revised 2017 manifold and it fits the same as my 2013. Sounds better too in the midrange due to the revised (more EL) layout. Bolt it on and enjoy.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
asdf (05-16-2021), scion fr-s (05-16-2021), Ultramaroon (05-16-2021)
Old 05-16-2021, 01:01 AM   #6
Silencio, old man. Stock header doesn't have anything to do with "loud."
He's right. I have no idea.
BrahmaBull1990 (05-23-2021), humfrz (05-16-2021), scion fr-s (05-16-2021)
Old 05-16-2021, 02:14 AM   #7
Does to, old man. I reckon you went and forgot about what an engine sounded like without the stock manifold -
Old 05-16-2021, 02:20 PM   #8
jflogerzi
jflogerzi's Avatar
100% works.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
DarkPira7e (05-16-2021)
Old 05-16-2021, 02:30 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
For what it's worth, the only difference in the entire exhaust is the axle back flange near the diff everything else fits perfectly. This just means you can't mix and match exhaust from the midpipe to the axleback, but it's fine if you swap the whole catback
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (05-16-2021), Ultramaroon (05-17-2021)
Old 05-16-2021, 08:21 PM   #10
jflogerzi
jflogerzi's Avatar
What this man said. I was just to lazy to type out all that
Old 05-18-2021, 12:31 AM   #11
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Thanks for clarifying.
Old 05-18-2021, 02:25 AM   #12
PulsarBeeerz
Drives: JRSC BRZ SOLD
It fits fine, but the header flange is about 1/4" farther forward than the MY13-16. So the rest of the exhaust system will be pulled forward by that amount. Its not terrible but you will notice it during the install.
PulsarBeeerz is offline   Reply With Quote
Old 05-23-2021, 05:04 PM   #13
mrhood
Thanks for the replies, everybody! Great help, and looks like I will be getting the 2017 header I found for sale. Thanks again
2017 86 Header Compatible with 2013 FRS? mrhood Scion FR-S / Toyota 86 GT86 General Forum 4 05-06-2022 07:14 PM
Can I pass smog with a 2017+ header on my 2013? norcalpb Northern California 6 08-23-2020 03:33 PM
2014 engine compatible in 2013 car? Meppster Engine, Exhaust, Transmission 3 09-03-2019 06:20 PM
Aftermarket Intakes Still Compatible with 2017? Xeneon Engine, Exhaust, Transmission 7 04-19-2017 09:21 PM
Is Unichip 2013-14 compatible with 2015? babydriver Software Tuning 4 06-03-2015 10:40 PM
