Old 05-16-2021, 01:32 AM   #1
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
Oil pressure
I tapped in off the Oil pressure sensor from the oil cooler plate(mishimoto cooler), at cold start pressure was @100 psi(only have a 100psi gauge for now). Once warmed up, at idle held about 20psi. Driving in 6th gear, 2-3k rpm around 50psi.
I’ve read people getting 10 psi at idle.
I have a Killer bee Oil pick up tube since I’m boosted.
The car itself, 2020 Brz anyone else have these pressures?
Limitless_BRZ is offline   Reply With Quote
Old 05-16-2021, 10:59 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those are normal numbers.
Old 05-16-2021, 11:56 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What is the "oil cooler plate"? Do you mean the sandwich plate? What gauge/sensor is this? What oil weight?
Your numbers seem good, but they will differ a bit based on where you're sampling from.
At least you know if it's ever not reading at what you're used to see, the road may get bumpy
Old 05-16-2021, 01:35 PM   #4
Limitless_BRZ
Yeah i meant the sandwich plate, its just a cheapo glowshift until my aem ones come in.
Im running 0w-20, JDL turbo, upgraded radiator, fan shroud, oil cooler and waiting on a vented hood as well. Trying to keep temps down as much as i can in arizona.
I think once my AEM gauges come in, ill be going off the OEM oil sensor location
Old 05-16-2021, 02:12 PM   #5
DarkPira7e
DarkPira7e's Avatar
I spent 2 weeks in Tucson years ago, sometime late March.
Highs were in the 30s here in Vermont. During my stay, it was 80-90 in Tucson- I can't fathom trying to manage oil temps during summer, best of luck!
Old 05-16-2021, 02:47 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Being you are FI and in a warm climate, I would keep an eye on it. Min pressure at idle per FSM is 7.3psi at 176F oil temp. If you are getting the car hotter in traffic you may want to go to 5-30w. Recommended oil pressure at 6k RPM is 73psi at 176F oil temp.
Old 05-16-2021, 03:06 PM   #7
Limitless_BRZ
Yeah ive done all i could for now, next step is vented hood, and maybe figure out a way to cool the oil a bit more. Driving to and from work 30 miles one way all highway, oil temps get to about 205F
Old 05-16-2021, 07:47 PM   #8
Something seems weird about this. The mishimoto is sized about right. Where is it mounted? Are you sure you're getting good airflow?
Old 05-16-2021, 07:59 PM   #9
DarkPira7e
DarkPira7e's Avatar
If he's doing the highway in Arizona, ambient is probably 106f this time of year. Who knows how much heat the pavement radiates, and he's probably averaging 80mph, which is pretty high in the revs for a long time.
205 doesn't seem unbelievable, but I didn't get to run mine for too long in temps over 70f
Old 05-16-2021, 08:11 PM   #10
Yeah. It's not awful. Good point about ambient temp.
Old 05-16-2021, 08:21 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Actually, in those conditions at that speed 205f seems downright reasonable. In deep south Texas at ambients of 100f +/- the oil temp on my NA ran just over 200 at 75-80. Over the pandemic I installed a o2w wrx/forester cooler and haven't had a chance to do an extended highway run yet.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-17-2021, 02:38 AM   #12
Limitless_BRZ
Sadly not going 80, I stay around 70 just cause I don’t wanna high rev the whole way & let the temps rise.
I will update more thru the week.
My oil
Old 05-17-2021, 02:39 AM   #13
Limitless_BRZ
It’s mount slightly off center
Old 05-17-2021, 11:27 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is it mounted on the undertray?
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 10:32 PM
Oil Pressure nearvincent Engine, Exhaust, Transmission 3 04-12-2017 07:46 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
