Old 05-05-2021, 05:54 PM   #1
DJjoey0812
Drives: 2013 Scion Fr-s
Stuttering and exhaust pop when accelerating
Lately my car when accelerating will stutter and pop when it stutters, I had a cel for a fuel injector but it dissapeared and has not come back on and the issue is getting worse any ideas?
DJjoey0812 is offline   Reply With Quote
Old 05-05-2021, 07:37 PM   #2
You have a bad fuel injector.
alphasaur (05-08-2021)
Old 05-05-2021, 08:54 PM   #3
DJjoey0812
Well how do I figure out which one I don't wanna just replace all 4
Old 05-05-2021, 10:21 PM   #4
anticubus
Drives: 2017 Toyota 86
The code should still be stored after the CEL is out, run to the local parts store that does code reads (autozone) and see if they can find any if you don't have a reader yourself.
anticubus is offline   Reply With Quote
Old 05-05-2021, 10:38 PM   #5
Hi ya, DJjoey0812 -
Welp, I checked with my buddy Bubba and here is what he suggests:
* Fill up with some premium gas from a station other than the one you usually use.
* Add some fuel injector cleaner.
* Do an Italian tune up
* Purchase an inexpensive code reader and read any code(s).
OR ...... go with the humfrz method - take the car into the shop and ask them to fix it.
BrahmaBull1990 (05-06-2021), jcw99 (05-09-2021)
Old 05-08-2021, 11:32 AM   #6
DJjoey0812
Fuel injector ecu bracket
The bottom ground bolt was loose
The Following 6 Users Say Thank You to DJjoey0812 For This Useful Post:
alphasaur (05-08-2021), bcj (05-08-2021), humfrz (05-08-2021), jcw99 (05-09-2021), soundman98 (05-08-2021), Tcoat (05-08-2021)
Old 05-08-2021, 02:37 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
thanks for updating us on the solution!
Old 05-12-2021, 10:59 AM   #8
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
Be careful, this happened to me and while my DI ecu kept working it eventually fried something and I had a big shitfest replacing that and a coil pack. Exact same presentation. CEL came on, went away, and then I went WOT and car went into limp home mode.
Ignore Your Doctor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ignore Your Doctor For This Useful Post:
soundman98 (05-12-2021), Tcoat (05-12-2021)
VVT goes off for 1 second accelerating in 6th tomm.brz Software Tuning 16 10-31-2018 12:44 PM
Not accelerating Fresh31 Issues | Warranty | Recalls / TSB 15 03-17-2018 06:05 PM
Please help.. Car not accelerating Joseph Issues | Warranty | Recalls / TSB 9 09-08-2015 12:55 PM
Stuttering/ticking noise while car is parked? jermyzy Issues | Warranty | Recalls / TSB 4 03-02-2014 08:35 PM
driving in 1st weak/stuttering feeling deedz Scion FR-S / Toyota 86 GT86 General Forum 19 07-25-2012 07:33 PM
