Old 03-16-2018, 11:25 PM   #1
Fresh31
Fresh31's Avatar
Drives: 2015 frs
Not accelerating
Hey guys, trying to see if I can get some direction as to what's going on.
If I try to accelerate quickly in 4th or higher, my engine revs but the car doesn't accelerate. It's worse in 5th and 6th than in 4th.
Is the tranny dying or is it something else?
Car is manual transmission and turbo.
Thanks!
Fresh31 is offline   Reply With Quote
Old 03-16-2018, 11:27 PM   #2
Boomerang
86
Boomerang's Avatar
Thanks!
Clutch worn if you are manual transmission.
Fluid or worn if you are auto.
Old 03-16-2018, 11:29 PM   #3
Fresh31
Fresh31's Avatar
Drives: 2015 frs
It would please me greatly if it's just the clutch.
Old 03-16-2018, 11:30 PM   #4
Boomerang
86
Boomerang's Avatar
Sounds like it is
Old 03-16-2018, 11:31 PM   #5
Fresh31
Fresh31's Avatar
Drives: 2015 frs
Sounds like it is
Before it started doing that, it would hesitate slightly like a stutter than it would start working.
Old 03-16-2018, 11:33 PM   #6
Boomerang
86
Boomerang's Avatar
Just noticed you edited your first post to include your TURBO!
It is recommended you upgrade your clutch if you go turbo, for exactly the reason you are experiencing now..e.g worn clutch-too much torque for stock clutch
Old 03-17-2018, 12:32 AM   #7
humfrz
Thanks!
Sounds like either your clutch is way out of adjustment or (like others have said) .....the clutch disk is worn out.
I suggest that you do this simple test. Warm up the car, set the emergency brake, put the car in 2nd gear, rev to about 3000 rpms, slowly let the clutch out. If the engine still runs with the clutch out, most likely the clutch disk is worn out. If the engine dies, the clutch still has some life.
humfrz
Old 03-17-2018, 01:39 AM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Clutch. All up down and sideways.
Classic symptoms of clutch shaved down to nothing.
Higher gears apply even more torque to a surface that cannot cope with it anymore.
Old 03-17-2018, 03:24 AM   #9
Oh this is an easy one!
What everybody else said.
Old 03-17-2018, 11:08 AM   #10
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I know a few local guys who upgraded their clutch right away after boosting their car, because it would slip under boost. I don't think the stock clutch disc can handle much more power than stock.
I know everyone has already said clutch, but it's clutch that you understand that it is your clutch that is not clutching. I mean, probably.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 03-17-2018, 11:56 AM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Sounds like your clutch is slipping.
Old 03-17-2018, 04:16 PM   #12
humfrz
........ I suggest you drink more coffee in the morning before posting .....
humfrz
Old 03-17-2018, 04:21 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
Thanks!
IT'S A SLOOOW CAR! GET USED TO IT!
Old 03-17-2018, 04:45 PM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
humfrz
Why?
Pop noise when accelerating sometimes Jfheisenberg Engine, Exhaust, Transmission 5 10-09-2017 07:39 PM
Please help.. Car not accelerating Joseph Issues | Warranty | Recalls / TSB 9 09-08-2015 11:55 AM
Pulsing when Accelerating carma143 Issues | Warranty | Recalls / TSB 41 02-27-2015 08:29 PM
accelerating from a dead stop jarviz Scion FR-S / Toyota 86 GT86 General Forum 78 07-26-2012 02:11 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
