Old 10-27-2018, 05:10 AM   #1
tomm.brz
Drives: brz 2017 hksv2
VVT goes off for 1 second accelerating in 6th
Guy I know had a problem during the remap with a british remote master tuner, that couldn t fix the problem
he was also using racerom 9.1 and didnt have the "vvt enabled" voice to log
With racerom 10 I put in the problem is still there (tune in the log is just started from scratch, MAF still not scaled well, but fixed by racerom v10 closed loop fuel control)
Can't say if it happens with a stock rom, we didn t tray and would also be annoying cause he has catless header and a strange AEM air intake
https://datazap.me/u/tommbrz/vvt-dis...&mark=783-1113
So he is in 6th gear and accelerates, and for 1 second VVT goes off
intake and exhaust cams flat to 0 and seems to go in the ignition timing VVt off map (what would be Base timing A in romraider)
injections seems to be good as they still inject without esitations
also throttle seems ok from the log, no change in throttle angle during the "defect"
then VVT just restarts and cams go quickly to where they should be
It seems to happen always only in 6th gear and between 4500 and 5000 rpm
no DTCs
car is my13 NA ,has oil cooler and 10w50 oil (his choice)
but he has 10w50 since always and only got the problem lately
calId is ZA1JA02G, i sent him an identical tune but A01G, hoping in some ecutek bug, but hasn t tried yet
What could be the problem?
Old 10-27-2018, 05:54 AM   #2
steve99
First thing i would try is using stock intake ibstead of the AEM intake, those intakes are terrible.
Also dont use the extansion cable box for the maf its got some electronics in it that tries to fool ecu by altering maf sensor input signals, it just causes more issues.
Old 10-27-2018, 06:04 AM   #3
tomm.brz
ETI module of aem intake is already out.
i doesn t look a problem with the maf to me.. also with the maf scaled by the master tuner, the car did run good for many releases
then suddenly got this problem, only in 6th
CL fuel control is enabled and maf in that log is off of about 11% in that open loop zone, but the cl fuel control corrects it well
could be the oil too thick causing problems?
Old 10-27-2018, 06:44 AM   #4
steve99
Its possible the vvt turning off is the ecu going into limp mode.
Its possible tge ecu is not getting a signal it exoects from a sensor, possibly cam sensor or even maf, or another sensor that would cause limp mode.
Strange its not setting any cel codes.
Id try loading stock tune just with P0420 disabled for header
You need to go through a process of elimination
Check any connections that may have been disturbed
Look for strange sensor inputs like weird afr or cam positions , or map sensor.
Check knock if iam gets below certian value it could trigger limp mode
Check DI computer box is mounted via all bolts
If you have spare ecu try replacing that
If you have access to techstream use that for looking at cel codes, it reads storred or transient codes, not just current codes like a lit of code scanbers
Remove as many mods as you can easily and revert to stock tune with no racerom features or changes
Old 10-27-2018, 02:35 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Are you logging both banks and both commanded and output values?
Oil pressure could be a cause but then I would expect the same in other gears.
Testing an A01G would be a good shout, as I've said previously I stopped using A02G as I found issues that reverting back cleared.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-27-2018, 03:30 PM   #6
tomm.brz
a01g did same thing, only in 6th and more than 140 km/h
with stock map, it doesnt do it
if i use my tune, or tune from the master tuner but change cam timing more similar to UEL it does just very briefly, at higher rpm and speed, sometimes doesnt even do it
ETI module never used in these test
i logged all i could for VVT, bank 1 goes exactly like the target, bank 2 is a bit slower responding after 4800 rpm
no CEL
he also has greddy big snorkel, i m trying to let him do a test without the cover of the AEM airbox, to exclude maybe pression of the air that enters?
Old 10-27-2018, 06:23 PM   #7
Tor
Tor's Avatar
Drives: Toyota GT86
Do both cams otherwise reach the values in the AVCS low detonation tables (except where it VVT if off)? E.g. are you asking the intake cam for 40 deg but it only reaches 38.xx?
Tor is offline   Reply With Quote
Old 10-27-2018, 06:52 PM   #8
tomm.brz
1 bank reaches 39 and the other 40, with 40 of target
but that i often see specially with EL header and standard ots v2 EL stage2 cam timings
the cams seem to follow target pretty well (bank2 just a bit slower in lowering timings at high rpm)
i ll post some new logs later
next try are again lower cam both intake and exhaust around 4500-5000rpm, and open the AEM box in the top
i dont think it s a limp mode, i thought limp mode would throw CEL and some lights in the dash, it only seems like VVT goes dead for a second
Old 10-27-2018, 11:45 PM   #9
steve99
If you say it ok on stock tune
Try just inserting the intake and exhaust cam tavles in the stock tune and then see if that causes issue
Old 10-28-2018, 03:13 AM   #10
Tor
Tor's Avatar
Drives: Toyota GT86
Try lowering the intake cam to 38 deg as a max all over. It's speculation, but maybe it tries to drive the cam to 40, but as it can't, it reaches some kind of physical stop and "give up". I don't think these sensors are really accurate. Some cars will reach 40 others won't.
Old 10-28-2018, 07:47 AM   #11
tomm.brz
tests were a bit problematic
first he tried my latest working map but without AEM top cover, car pulled strong but maf scaling was pretty of specially around idle and low load, then again in 6th around 4500rpm accelerating vvt went off to 0 briefly
aem top cover put on again so maf scaling was again ok
sent him an identical tune but with stock cam timings
he said vvt was staying off all the time, "vvt enabled" went never to 1
he flashed back the tune with EL cam timings that worked untill 10 minutes before, but
vvt again never went on
seems strange to me, almost as he didnt wait enough but it was actually taking longer than usual as I was checking proecu all the time through him
he flashed back the master tuner's tune (that has racerom v9.1 , mine has racerom v10)
after a while cams started to move so vvt went on
so plan is: he will flash again my tune with stock cam timings hoping vvt will go on and try if the problem in 6th gear is gone with stock cam timings
The mishimoto oil cooler is keeping his 5w50 Mobil1 oil at less than 88 Celsius all the time so he also wants to try chsnge oil to a 5w30 soon
Old 10-28-2018, 09:47 PM   #12
Tor
Tor's Avatar
Drives: Toyota GT86
I don't think there is a reason to use the stock tables. I will almost guarantee that all you have to do is lower the cam to 38 or 39. But not just where the problem is. Use it as a max in the whole table.
The cam is controlled by a PID controller. I think this is integral windup and the controller giving up after a set time, which may be why you see it only in 6th gear as the pull last a long time.
https://en.wikipedia.org/wiki/Integral_windup
Old 10-31-2018, 02:13 AM   #13
tomm.brz
Tor, thank you, that fixed the problem immediatly
i putna max of 38 and car is still pulling strong, and the vvt dip in 6th gear is gone
Old 10-31-2018, 04:09 AM   #14
steve99
Yes the suggestion to ise srock cam mapping was just to test if that was problem, looks like you foumd the issue
Good work
Whine when accelerating Geex Issues | Warranty | Recalls / TSB 9 07-21-2018 03:35 PM
Not accelerating Fresh31 Issues | Warranty | Recalls / TSB 15 03-17-2018 05:05 PM
Pop noise when accelerating sometimes Jfheisenberg Engine, Exhaust, Transmission 5 10-09-2017 07:39 PM
Please help.. Car not accelerating Joseph Issues | Warranty | Recalls / TSB 9 09-08-2015 11:55 AM
Pulsing when Accelerating carma143 Issues | Warranty | Recalls / TSB 41 02-27-2015 08:29 PM
