Old 07-27-2012, 01:05 PM   #155
EZWood
BAMF
EZWood's Avatar
Two guys one car...dd
EZWood is offline
Old 07-27-2012, 01:12 PM   #156
vividracing
vividracing's Avatar
While this has been great fun. Nothing was more bad ass then hearing you go around the block last night.
Hahahah
vividracing is offline
Old 07-27-2012, 01:15 PM   #157
EZWood
BAMF
EZWood's Avatar
When the t/c and abs was freaking out? I fealt like I just got off a rollercoaster.
EZWood is offline
Old 07-27-2012, 01:19 PM   #158
d1ck
Drives: Black 2013 FRS
If that should happen again it might be a good idea to just pull the abs fuse.
d1ck is offline
Old 07-27-2012, 01:24 PM   #159
vividracing
Haha you had the most straight face. But sure did sound like a good time.
I forgot about that trick. And I will look into it.
Thanks for the help.
Old 07-27-2012, 01:34 PM   #160
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Originally Posted by vividracing View Post
An update for everyone.
The car has learned the dyno runs. The AFR's are dropping hard up top and choking power. Last runs have seen a 10.1 AFR up top Which started to happen last night. This has choked power above 6k rpms+
As I start to post up things I will post this and you can see the power hit it has made. We are looking into it now. This problem came up running the Header, Cross-Over pipe and Catback.
I will make sure to point this out when I post the chart for this run. Since the single part runs have made more power. And we have logged the AFR's. You can see the tank and then power go flat.
But please keep in mind this is the 1st time we have seen this and this car doesn't have a tune.
I'll keep updating
I know that the ECU needs a bit of time to 'relearn' the setup, so it is quite possible that the full setup won't show the gains that are present after a few hundred miles. That's why dyno testing is an inherent issue if you don't have a fully understood and programmable ECU.
New platforms are always an issue.
Symbiont is offline
Old 07-27-2012, 01:34 PM   #161
EZWood
BAMF
EZWood's Avatar
Yea, with the way the weight is distributed on these cars and the added power the cqar rotates a lot faster.
EZWood is offline
Old 07-27-2012, 01:49 PM   #162
vividracing
Yes the new platform has a learning curve. Ecu stuff is not new to Jason, Matt or myself. Just this platform is. Learning curve for all.
Back out on the dyno.
Old 07-27-2012, 03:49 PM   #163
vividracing
Crank pulley. Header. Crosspipe. Catback done.
Few more combos left.
The Following 3 Users Say Thank You to vividracing For This Useful Post:
civicdrivr (07-27-2012), CoRi J (07-27-2012), Tomzilla (07-27-2012)
Old 07-27-2012, 04:07 PM   #164
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
subscribed
CoRi J is offline
Old 07-27-2012, 04:17 PM   #165
EZWood
BAMF
EZWood's Avatar
Ha, you ladies had better get your checkbooks ready, convert your Hawaiian money over to American money, and make sure your f5 buttons are in proper working order for when these results are posted up.
EZWood is offline
Old 07-27-2012, 04:20 PM   #166
vividracing
I am working on updating. I do wonder if it is better to start a part III and post a link to that thread here and have this thread locked?
What do you guys feel is best? I feel that lets the info posted here be here, our claim stays as well. Then for the new info people will not have to dig thru this thread to find it.
I would not like to add to the 1st post as it then shows its been edited. Which brings up questions.
So let me know if lock this thread and part III is best path.
Old 07-27-2012, 04:26 PM   #167
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Post a new post here and then link to that post in the original one with something like:
Edit: Click here to see the outcome of our testing! <HTMLLINKGOESHEREFORGREATJUSTICE!>
denkigrve is offline
Old 07-27-2012, 04:34 PM   #168
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Go for part III
Sportsguy83 is offline
Agency Power Exhaust for the BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 07-23-2012 11:57 PM
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
Agency Power Exhaust | Best Price Anywhere IslandImportPerformance Engine, Exhaust, Bolt-Ons 13 07-21-2012 10:50 AM
Agency Power Exhaust in the works! PrimeMotoring Engine, Exhaust, Transmission 67 07-17-2012 06:57 AM
