Old 08-22-2017, 07:06 PM   #1
NRXRaptor
High Pressure Fuel Pump and Aftermarket Headers
I'm having the fuel pump replaced under warranty, as I figured I might as well take advantage of the warranty and try to get rid of the crickets at least once. I also am going to have headers installed soon. My question is:
Do you think the dealer will care that I have aftermarket headers and a tune from open flash tablet on the car? I have no idea
NRXRaptor is offline   Reply With Quote
Old 08-22-2017, 11:58 PM   #2
Impureclient
Drives: 2015 FR-S
Probably would depend on the dealer. I have a header and tune and they didn't give me any problems about getting the new fuel pump in.
If you don't have the header/tune in yet, just wait until after the pump is changed out.
The Following User Says Thank You to Impureclient For This Useful Post:
humfrz (08-23-2017)
Old 08-23-2017, 01:53 AM   #3
NRXRaptor
Alright, I'll just wait. I'm just anxious. Finally doing more to my car than just rice
Old 05-12-2019, 07:50 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Sorry to necropost, but here I am.
Is there an aftermarket low pressure and high pressure fuel pump for the twins?
I'm looking to upgrade the whole system and go FF
guybo is offline   Reply With Quote
Old 06-14-2019, 05:15 PM   #5
wparsons
wparsons's Avatar
FF? There's tons of low pressure pump options, just depends on how much flow you need. If you're staying N/A, there's no need to replace any of them at all. If you're going boosted then you just need to upgrade the low pressure pump and port injectors at most. Leave the HPFP and DI alone.
flickr
Old 03-28-2021, 02:18 PM   #6
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
So was anyone able to swap the HPFP and remove the crickets with one of these, or something else.
https://www.ftspeed.com/search?q=fue...BRZ%20%2F%2086
ClevelandFRS is offline   Reply With Quote
Old 03-28-2021, 02:27 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those are in tank pumps. The pump that causes the crickets is the HP pump bolted to the driver side head. Again, there is no aftermarket replacement.
DarkPira7e (03-28-2021)
Old 03-28-2021, 04:15 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Can the 17+ MY pump be swapped onto the earlier heads? Asking for a friend....
Old 03-28-2021, 04:23 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes. I think the old
Pump part number will supersede to the newest. Not 100% though.
Edit: checked and all years show compatible with the newest pump. Looks like it has been superseded a few times. Only 1 part number available for all years mt or auto.
So chirping noise from high pressure fuel pump Nefarious Issues | Warranty | Recalls / TSB 19 03-12-2017 11:49 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-24-2016 12:36 AM
high pressure fuel pump = 5 years / 100 000 km ? jefars Issues | Warranty | Recalls / TSB 7 09-16-2016 02:26 PM
High Pressure Fuel Pump Thread crazyfrenchbiker Engine, Exhaust, Transmission 10 09-09-2015 02:32 AM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 07:48 AM
