Old 03-25-2021, 03:58 PM   #1
Rocketman
Drives: 2013 Blue FR-S
Broken suspension bolt
So, I previously asked for help with a handling problem on my FR-S.
https://www.ft86club.com/forums/show...57#post3382157
I have attached pictures from my mechanic showing a broken bolt from a Whiteline camber adjustment kit. I was concerned the problem might be to subtle for him to diagnose. Guess not.
Comments?
Rocketman is offline   Reply With Quote
Old 03-25-2021, 04:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
WTH are you trying to show.
The first picture is a transmission mount.
The second picture is the trailing arm.
Picture 3 does show the rear LCA which is the only camber adjustable part for the rear of the car WL sells and it looks fine, in fact it looks stock.
Pictures 4 and 5 look like the upper control arm bolts to the subframe which are broken. WL does not make a camber bolt for this. I would be questioning this mechanic, and what he installed. Those broken bolts do not look like any camber bolt I have ever seen.
EDIT: Ahhh, I see now. It is this part.
https://whitelineperformance.com/pro...26-bushing-kit
I would contact whiteline and send them pictures to see what they say. I have a feeling they are going to ask, "what were they torqued at?" It is what I would ask.
DarkPira7e (03-25-2021)
Old 03-25-2021, 05:37 PM   #3
Grady
Grady's Avatar
The broken bolt on the upper arm in the back answers the question on why you thought you had “torque Steer”. Now replace it and it is fixed. Any other questions?
Old 03-25-2021, 06:33 PM   #4
Rocketman
Thanks, glad you could edit it before I saw it. I just attached what the mech sent to me, and tried to explain it to me, but I don't know much. He recognized it as a Whiteline product (!) and he is pretty smart. He says he had to get a used mounting part (again, not sure what i am talking about) that was damaged (elongated hole) by the movement of the part that was unrestrained by the broken bolt. And he is waiting on Whiteline to get a replacement part. I don't know if he is talking to them about the failed part. I just said, "Fix it, Jorge."
Old 03-25-2021, 07:09 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In the installation instructions they say to check the torque after 100km. Looking at the 4th picture and how it elongated the hole, it looks like it backed out and the movement broke it off. I'd make sure to retorque it after some driving to prevent this.
handlnig problem, suspension failure
Suspension bolt stuck? Rubedo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-25-2020 12:18 AM
Broken ignition coil bolt UNCC_BRZ Engine, Exhaust, Transmission 9 03-19-2019 11:19 PM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 10:29 AM
Broken Assembly Bolt VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-18-2016 11:02 PM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 01:48 AM
