Old 05-24-2020, 12:32 AM   #1
Rubedo
Miami to Montana
Suspension bolt stuck?
Having loads of trouble removing these two bolts from the front struts.
Anyone have tips or tricks? I’m using an impact wrench and soaked in wd40 and they just won’t budge
11/26/2018 - 2016 Limited M/T Crystal White Pearl
Been lurking this forum since 2011 and finally bought one haha
Rubedo is offline   Reply With Quote
Old 05-24-2020, 12:55 AM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Breaker bars. Stand on the handle.
Drifter X is offline   Reply With Quote
The Following 3 Users Say Thank You to Drifter X For This Useful Post:
FRS13_ (05-28-2020), Rubedo (05-24-2020), soundman98 (05-24-2020)
Old 05-24-2020, 12:59 AM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Soak 'em overnight. Otherwise a breaker bar + gym membership or some heat, via a torch.
If you wrench often and run into seized, rusty steel hardware and induction heater for bolt removal is an amazing tool to have. Red hot in 30 seconds without an open flames.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
Old 05-24-2020, 01:07 AM   #4
Rubedo
Miami to Montana
Lmao so I just did this and I’d like to tell you a funny story about how I no longer own a breaker bar haha
The Following User Says Thank You to Rubedo For This Useful Post:
Ultramaroon (05-24-2020)
Old 05-24-2020, 01:09 AM   #5
Drifter X
Drifter X's Avatar
Holy shit what?!?!?! Hahahahah!
Old 05-24-2020, 01:09 AM   #6
Rubedo
Miami to Montana
I’m going to let it sit over night and then try the torch method.
After torching. Is it ok to immediately take an impact wrench to it?
I’ve wrenched a lot but I guess I’ve had my fair share of luck with just taking the impact fun and things just coming loose after a few pulses
Old 05-24-2020, 01:11 AM   #7
Rubedo
Miami to Montana
See photo. Lmao. Bad luck tonight.
Old 05-24-2020, 01:33 AM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Get them red and then go. Just no they will be hot, so once they break back off as you don't want them dropping or flying around upon removal.
Old 05-24-2020, 01:49 AM   #9
Drifter X
Drifter X's Avatar
Oh man. I’m sorry.
Old 05-24-2020, 07:23 AM   #10
jRuN
You weren't trying to turn that side of the bolt were you? You gotta loosen the other side with the nut.. Not the bolt side.
Sent from my Pixel 3a using Tapatalk
jRuN is offline   Reply With Quote
The Following User Says Thank You to jRuN For This Useful Post:
Rubedo (05-24-2020)
Old 05-24-2020, 09:22 AM   #11
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
yes, the upper bolt is the adjustment. counter the bolt and loosen the nut. always.
it is best to use a 6 point socket and an impact quality will withstand higher loads.
the box stores will have 3/4" drive parts individually and you still might need to throw a pipe on the handle to extend it. (19mm is close enough to a 3/4" socket.)
I break all my bosses harbor freight tools for fun because its junk.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
Rubedo (05-24-2020)
Old 05-24-2020, 01:20 PM   #12
Rubedo
Miami to Montana
Ran over to autozone and bought a 2ft 1/2 in drive breaker with a new 19mm deep socket. Got the top out on drivers side. Working on bottom now.
😂 I’ll be changing all the hardware. I’ve never had this much trouble before. I guess I wasted all my luck on my old Miata where everything came apart with much ease.
Old 05-24-2020, 01:55 PM   #13
ls1ac
ls1ac's Avatar
Only heat the nut, It will expand, then breaker bar. HF impact black sockets are tough, Hex not twelve sided.
edit: a few auto parts stores will lend tools. like 3/4 drive
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Rubedo (05-24-2020), soundman98 (05-24-2020), Ultramaroon (05-24-2020)
Old 05-24-2020, 07:10 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
can always add a pipe to it!
Rubedo (05-24-2020)
What's actually holding the suspension together when you use an OEM crash bolt? 2Wavy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-25-2019 08:54 PM
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt Gopherboy6956 Engine, Exhaust, Transmission 16 11-23-2017 11:56 AM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
BRZ STI ts Bolt+Collar for rear suspension cslntuee Brakes, Suspension, Chassis 3 03-03-2015 04:13 PM
Stuck on which suspension setup to get mou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-25-2013 12:26 AM
