go_a_way1
Old 03-08-2021, 09:02 AM   #4355
Vital
Drives: 2015 BRZ
Originally Posted by CannibalPie View Post
Upgrading from stock wheels and suspension.
17x8.5+45 TE37 Sagas (square setup)
245/40/17 Tires
Tein Flex Z Coils (likely a 1'' drop, want to retain daily drivability)
Any concerns?
No concerns at all, go for it.
Old 03-12-2021, 11:24 AM   #4356
Angier
Drives: Subaru BRZ
I acquire assistance
I have ESR SR01 18x9.5 +35mm, I’m on stock suspension just for now until next month or so. What size tires would you guys recommend with no rubbing?
Angier is offline   Reply With Quote
Old 03-12-2021, 12:07 PM   #4357
Sev995
Drives: Black 2013 frs
235/40/r18 is what I'm running with 18x9.5 +35
Sev995 is offline   Reply With Quote
Old 03-12-2021, 12:11 PM   #4358
Grisha
Grisha's Avatar
Drives: '13 FRS
You can run 245/35/18 (this size has been recommended by many if you search the thread), or 235/40/18 (suggested above). I ran both and prefer the first one since there's less stretch.
Grisha is offline   Reply With Quote
Old 03-17-2021, 04:25 PM   #4359
gpvecchi
gpvecchi's Avatar
Sorry, 225/40-18 ET45, what are the biggest spacers I can run on front and back without rubbing the arches? Thanks!
EDIT: front and back camber is -1.5 degrees, with comber plates on te front and natural with lowering on the back
Old 03-23-2021, 10:49 PM   #4360
gta_fender_roll
Drives: Brz
Stock suspension with eibach lowering spring, 18x9.5 +38. What tire size to fit? I've been reading i may hit the spring perch.
Will running stretch set up help? 235/40/18 to clear? Please helppppppp
I roll fenders in Toronto area!!!!! Contact me on Instagram...
@gta_fender_roll
gta_fender_roll is offline   Reply With Quote
Old 03-26-2021, 10:49 AM   #4361
Vital
Drives: 2015 BRZ
It should fit worst case scenario if does not fit you can run a 3mm spacer up front. The tire sizes i would recommend are 245/35/18 or 225/40/18. If you go with a 245/35 tire size just know you will not be able to add any camber up in the front as that will rub. Yes, a stretch would help but personally im not a fan of stretching wheels.
Old 03-26-2021, 12:57 PM   #4362
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
The tire size will clear, unless it is unusually wide by design. I'm not sure if that rim size fits though? I have 18x8.5 +38 and it barely clears the spring.
Dzmitry is offline   Reply With Quote
Old 03-31-2021, 05:15 PM   #4363
Pataya
Drives: 2017 CWP BRZ PP
Any concerns with Advan RS 17x8 +37 clearing PP Brembos?
Pataya is offline   Reply With Quote
Old 04-03-2021, 05:55 PM   #4364
saltywetman
Drives: 2020 Toyota 86 GT 6M
How bad would the stretch be with the OEM Michelin pilot sport 4s 215/40r18 on 8.5" wheels? The rubber only has around 5k kms on them and ideally I would not buy new rubber for the new wheels until I wear down the stockers. Anyone have pix?
saltywetman is offline   Reply With Quote
Old 04-04-2021, 05:35 AM   #4365
Budglefudge
Drives: Toyota 86 2015
Hi Everyone,
I am thinking of two potential setups. Car is completely stock. at the moment. The two ideas are:
1. Square setup with:
18 x 8.5" 42mm Offset rims all round with 235/40R18 tyres.
2. Staggered setup with:
18 x 8.5" 42mm offset with 235/40R18 in the front
18 x 9.5" 45mm offset with 255/35R18 in the back.
Would either of these setups be fine? Leaning toward staggered as I think it would look cooler. Would I run into issues with the different diameter of fronts vs rears?
How flush would they be?
Also for context the rims I am thinking of going with are Motegi MR146, has anyone ran these on an 86? Cant seem to find info.
Thanks so much
Budglefudge is offline   Reply With Quote
Old 04-04-2021, 10:44 AM   #4366
Vital
Drives: 2015 BRZ
Sorry dont have any pics, but i can tell you its going to be a noticeable stretch. Probably wont be too bad as it is okay to use 215 width tires with those size wheels. Maybe someone else can post some pics...
The Following User Says Thank You to Vital For This Useful Post:
saltywetman (04-04-2021)
Old 04-04-2021, 11:08 AM   #4367
Vital
Drives: 2015 BRZ
Originally Posted by Budglefudge View Post
Hi Everyone,
Thanks so much
Personally, i'd go for the square setup. Both setups will work on stock suspension, but it isnt going to look good because its going to be poke and will look like a 4x4. Unfortunately none of these setups will be flush until you lower your car. The 235/40/18 is going to be kinda tall so you're speedometer is going to be off and will affect your gearing as well. Id get a 225/40/18 or 245/35/18 for fronts or a square setup.
Theres no problem running different tire sizes for a staggered setup. I wouldn't run staggered because theres no benefit in doing so. This car doesnt have enough power to warrant a staggered setup. Also, from factory this car was setup for a square setup so i would stick to that. You wont be able to rotate your tires either especially if you end up changing your suspension and a staggered setup makes it understeer more. If you care more about looks than go for it you'll get a lot of mixed responses about running staggered setups.
Old 04-04-2021, 03:04 PM   #4368
saltywetman
My main concern is the rim lip poking out too much and I miss dodging one of the multiple potholes in our pothole riddled roads and messing up a good wheel. Would like to not spend money on new tires with barely used stockers. but I'm also afraid cheaping out on rubber will cost me even more by permanently damaging some expensive wheels
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
