| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#4355 |
Drives: 2015 BRZ
#4356 |
Drives: Subaru BRZ
I acquire assistance
I have ESR SR01 18x9.5 +35mm, I’m on stock suspension just for now until next month or so. What size tires would you guys recommend with no rubbing?
#4357 |
Drives: Black 2013 frs
235/40/r18 is what I'm running with 18x9.5 +35
#4358 |
Drives: '13 FRS
You can run 245/35/18 (this size has been recommended by many if you search the thread), or 235/40/18 (suggested above). I ran both and prefer the first one since there's less stretch.
#4359 |
Sorry, 225/40-18 ET45, what are the biggest spacers I can run on front and back without rubbing the arches? Thanks!
EDIT: front and back camber is -1.5 degrees, with comber plates on te front and natural with lowering on the back |
#4360 |
Drives: Brz
Stock suspension with eibach lowering spring, 18x9.5 +38. What tire size to fit? I've been reading i may hit the spring perch.
Will running stretch set up help? 235/40/18 to clear? Please helppppppp
#4361 |
Drives: 2015 BRZ
It should fit worst case scenario if does not fit you can run a 3mm spacer up front. The tire sizes i would recommend are 245/35/18 or 225/40/18. If you go with a 245/35 tire size just know you will not be able to add any camber up in the front as that will rub. Yes, a stretch would help but personally im not a fan of stretching wheels.
#4362 |
Drives: 2018 Subaru BRZ Limited with PP
The tire size will clear, unless it is unusually wide by design. I'm not sure if that rim size fits though? I have 18x8.5 +38 and it barely clears the spring.
#4363 |
Drives: 2017 CWP BRZ PP
Any concerns with Advan RS 17x8 +37 clearing PP Brembos?
#4364 |
Drives: 2020 Toyota 86 GT 6M
How bad would the stretch be with the OEM Michelin pilot sport 4s 215/40r18 on 8.5" wheels? The rubber only has around 5k kms on them and ideally I would not buy new rubber for the new wheels until I wear down the stockers. Anyone have pix?
#4365 |
Drives: Toyota 86 2015
Hi Everyone,
I am thinking of two potential setups. Car is completely stock. at the moment. The two ideas are: 1. Square setup with: 18 x 8.5" 42mm Offset rims all round with 235/40R18 tyres.2. Staggered setup with: 18 x 8.5" 42mm offset with 235/40R18 in the frontWould either of these setups be fine? Leaning toward staggered as I think it would look cooler. Would I run into issues with the different diameter of fronts vs rears? How flush would they be? Also for context the rims I am thinking of going with are Motegi MR146, has anyone ran these on an 86? Cant seem to find info. Thanks so much
#4366 |
Drives: 2015 BRZ
Sorry dont have any pics, but i can tell you its going to be a noticeable stretch. Probably wont be too bad as it is okay to use 215 width tires with those size wheels. Maybe someone else can post some pics...
| The Following User Says Thank You to Vital For This Useful Post: | saltywetman (04-04-2021) |
#4367 | |
Drives: 2015 BRZ
Theres no problem running different tire sizes for a staggered setup. I wouldn't run staggered because theres no benefit in doing so. This car doesnt have enough power to warrant a staggered setup. Also, from factory this car was setup for a square setup so i would stick to that. You wont be able to rotate your tires either especially if you end up changing your suspension and a staggered setup makes it understeer more. If you care more about looks than go for it you'll get a lot of mixed responses about running staggered setups. |
#4368 |
My main concern is the rim lip poking out too much and I miss dodging one of the multiple potholes in our pothole riddled roads and messing up a good wheel. Would like to not spend money on new tires with barely used stockers. but I'm also afraid cheaping out on rubber will cost me even more by permanently damaging some expensive wheels
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
