Old 03-07-2021, 11:08 PM   #1
Aryanenzo
Drives: 2017 Subaru BRZ Inazuma
Humming sound after modifications. Please help me.
This is driving me insane enough to sell the car. I'm so done with it.
Recently I modified my car.
Installed the SPC Adjustable Lower control arms, new Konig Hypergrams, brand new pilot sport 4s tires, and Tein Flex Z coilovers. Lowered it an inch.
Alignment was 0.05 toe out in the front each side, and 0.05 toe in in the front each side.
The day after I got my tires, one of them was punctured. It was running at about 15 psi (not completely flat at all) and I drove it 3 blocks to the nearest tire shop by my house to get it repaired.
A week or so later I noticed a humming sound. I feel like its coming from the front passenger side but it could be from the rear and my right ear is picking it up.
Its a hummmmmm hummm hummmmmmmmmmmm hummm, kinda whirring, high pitched sound that's barely audible but I can definitely hear it.
- It doesn't change with speed. It comes on at about 20kph and its consistent in frequency and volume
- It doesn't change with turning, or changing lanes
- Its hard to tell if it changes with road surface type, if it does its very subtle.
- I feel like it changes a bit when I go over a bump, but I'm not sure, its very quiet.
- Changing the tire pressure didn't help.
- It doesn't change when coasting, it doesn't change with acceleration, it doesn't change with braking either
- I feel like it gets quieter once I get over 100 KPH.
I've heard everything from its my alignment, or that the SPC bushings are harder and i'm hearing the rear diff.
Any thoughts?
Aryanenzo is offline   Reply With Quote
Old 03-08-2021, 12:44 AM   #2
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Maybe get your wheels rebalanced or I'd inspect the hub assembly. Maybe a worn wheel bearing? Take it back to the shop that performed a the work.
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following User Says Thank You to FLIPDADY For This Useful Post:
StraightOuttaCanadaEh (03-08-2021)
Old 03-08-2021, 09:43 AM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Sounds to me like a bearing, almost sounds like you had a piece of metal stuck on the rotor. But like @FLIPDADY said, get them aligned/balanced and see if the shop missed something.
spcmafia is online now   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
FLIPDADY (03-08-2021)
Old 03-08-2021, 09:30 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
It might be also something simple as slightly bent during work on suspension/wheels dust shield around brake rotors that drags a bit.
Does that humming volume changes depending on which side turn you take? In that case imho high chance forwheel bearing being culprit.
churchx is online now   Reply With Quote
Old 03-08-2021, 10:53 PM   #5
Aryanenzo
As I previously mentioned, there's no way to get the frequency and loudness of the humming to reliably change.
It doesn't change when changing lanes or turning. It does't change when going faster or slower. It doesn't change under acceleration or braking. It's just kind there and its frequency and loudness is completely random. BUT the car needs to be moving over 30kph to hear it but after that its consistent more or less.
Also its not hum hum hum hum hum
Its more like hummmmmmmmmmmmmmmmm huuuuuuumm huummmmmmmmmmmmmmmmm It's totally random.
Old 03-09-2021, 02:05 PM   #6
Grady
Grady's Avatar
Post video of the noise. If all else fails, get louder exhaust or stereo.
Old 03-18-2021, 11:19 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
Did you install the parts yourself?
I had the e-brake line bend the little brackets such that they would rub against the wheel in some situations. I would be checking if anything is rubbing against the wheel or tyre.
1974 TA22 Celica
2013 86 GT
Old 04-19-2021, 01:29 AM   #8
jflogerzi
jflogerzi's Avatar
Rotate the tire that got repaired to the back. It could be an issue with a wheel out of balance, the tire being patched... if the sound follows you will know why
2013 Series 10 FRS #553
Humming Sound Similar to Wheel Bearing, but Possibly Not BooshTheMan Engine, Exhaust, Transmission 10 04-22-2024 05:23 PM
Humming Sound kmbkk Issues | Warranty | Recalls / TSB 44 01-01-2020 07:35 PM
Strange humming(ish?) sound coming from near rear wheels when car is off redwing634 Issues | Warranty | Recalls / TSB 2 04-02-2017 07:42 PM
Humming from front dphee79 Issues | Warranty | Recalls / TSB 3 04-24-2015 02:51 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 09:04 PM
