Old 11-15-2019, 01:45 PM   #1
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Humming Sound
Not sure exactly how to describe a sound I’m hearing from my car but I’ll try. It’s a humming sound I can hear above about 30 mph. The sound is similar to what an off-road tiee sounds like on the highway (tire hum I guess). It’s constant and the pitch increases as the speed increases. It doesn’t matter what the RPM is, so it isn’t transmission related. Also, I put on my winter wheels/tires this past weekend and that didn’t make a difference, so it’s not a tire issue either. I haven’t noticed any degradation in performance or handling. I didn’t see anything visibly when I swapped the wheels. I think it’s coming from the front of the car but am not 100% sure. It really isn’t much louder with the windows rolled down. I’m kinda stumped at this point🤷*♂️
Thanks in advance
kmbkk is offline   Reply With Quote
Old 11-15-2019, 02:00 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Time for new bushes???
The Following 2 Users Say Thank You to JD001 For This Useful Post:
humfrz (11-15-2019), kmbkk (11-16-2019)
Old 11-15-2019, 05:51 PM   #3
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Sounds like it could be wheel bearing , had some bad wheel bearings on my Wrx and it felt like you could hear it inside while moving .
mswbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to mswbrz For This Useful Post:
kmbkk (11-16-2019), NoHaveMSG (11-15-2019)
Old 11-15-2019, 06:01 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What is the mileage?
Speed related humming can definitely be a wheel bearing. Turning can increase the noise on the corner the bearing is worn.
A way to check is to Jack up the car and check the wheel for play. Up and down is often most accurate as left and right play can indicate a worn tie rod.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
kmbkk (11-16-2019), ScoobsMcGee (11-21-2019)
Old 11-15-2019, 06:01 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It sounds like front wheel bearings. You have to replace the hub as a unit. I am getting ready to replace my 3rd. I have been through 2 right fronts. Now the left is starting to make noise.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
kmbkk (11-16-2019)
Old 11-15-2019, 06:03 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine made noise before there was any play you could feel even with the hub removed. I had one get really bad on a drive home from the track to the point it would screech a bit. It only had a tiny amount of play.
Old 11-15-2019, 11:40 PM   #7
humfrz
humfrz
Old 11-16-2019, 03:49 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
humfrz
This sort of thing...
humfrz (11-16-2019), kmbkk (11-16-2019)
Old 11-16-2019, 10:08 AM   #9
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yep, that’s how the sound is. It’s isn’t overly loud, but definitely present.
Old 11-16-2019, 10:10 AM   #10
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Just went over 78k miles, 2013. And thanks for the suggestions, I’ll do some driving tests to see if I can determine the side!
Old 11-16-2019, 10:12 AM   #11
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Did you get them from a dealership or order them online?
Old 11-16-2019, 10:16 AM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
bushings make inconsistent clanking/screeching/grinding noises as the metal parts start to rub together. in this case, a speed-dependent humming sound would indicate something to do with the rotating assemblies. wheel bearings are one of the most common, also heard of similar noises with bad CV axles sometimes.
Old 11-16-2019, 10:37 AM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
I think that it can be a combination of things. Bearings, bushes and dampers as they degrade slowly over time and only start showing their failures (or should that read when the driver starts to notice) when they're near the end of their life.
Old 11-16-2019, 12:12 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Online and used. I got one from a wreaked car I was buying other parts from.
kmbkk (11-16-2019)
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 09:47 PM
Strange humming(ish?) sound coming from near rear wheels when car is off redwing634 Issues | Warranty | Recalls / TSB 2 04-02-2017 06:42 PM
AC Humming/Whining ericmpena Issues | Warranty | Recalls / TSB 2 06-08-2015 12:32 PM
Humming from front dphee79 Issues | Warranty | Recalls / TSB 3 04-24-2015 01:51 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 08:04 PM
