Old 02-15-2021, 05:18 AM   #127
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Originally Posted by EndlessAzure View Post
GT calipers are a little wider but shorter and overall are a little lighter than PP. GT calipers have an adapter to radial mount, while PP mount axially like base calipers.
Do you know what sized pistons are used in GT rears ? Just wondering if GT fronts can be used with PP/STI rears since disc sizes are the same for both GT/PP rears.
MrSkubi is offline   Reply With Quote
Old 02-15-2021, 05:26 AM   #128
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I don't. Didn't look a lot into GT rears since I don't plan on buying them.
Some forum posts say 40mm for PP rears, but I don't have any definitive info like a spec sheet or image of measurement
EndlessAzure is offline   Reply With Quote
Old 02-15-2021, 05:35 AM   #129
MrSkubi
MrSkubi's Avatar
Well I do have a set of STI rears laying on shelf. Just wondering If i could install them along with larger discs next time my rears are in need of replacing
Old 03-16-2021, 09:08 PM   #130
saltywetman
Drives: 2020 Toyota 86 GT 6M
does someone have measurements for the width of the PP caliper as well as the width of the 1P-.8002A- GT calipers? just curious how much thicker the GT is in comparison since the FTSpeed video mentioned the GT was thicker than the PP calipers
saltywetman is offline   Reply With Quote
Old 03-16-2021, 10:02 PM   #131
EndlessAzure
Wheels for Brains
326mm GT poke about 3mm more than the PP.
Don't know how width compares, but the mounting method is different too
There are templates available for the kit
The Following User Says Thank You to EndlessAzure For This Useful Post:
saltywetman (03-17-2021)
Old 03-17-2021, 12:57 AM   #132
saltywetman
Thanks! will try out template once i remove my winter wheels so i can measure the inside with it. I know the ptr2018160bk wheels are confirmed to fit PP brembos but not sure if the clearance is so tight that the added thickness of the GT calipers would make it not fit.
Old 03-19-2021, 12:37 AM   #133
EndlessAzure
Wheels for Brains
Yeah it may be tight. Both of my current wheel sets fit with PP Brembos, but I've needed to get a set of 3mm spacers to make them work with GT Brembos
I also put the GT template on a PP spare wheel, and it also needs a 3mm spacer to work
saltywetman (03-21-2021)
Old 04-15-2021, 01:48 AM   #134
MrSkubi
MrSkubi's Avatar
I'm leaning toward PNs: 26290CA020 and 26290CA030
They're the right PNs .
If someone ever wondered here are corresponding Toyota PNs:
SU00306803
SU00306804
From my experience it was easier to source them through Toyota dealership.
Old 12-30-2021, 02:30 AM   #135
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Just found this old thread. Interesting read!
For a more focused thread that doesn't (yet? ) have an off-topic holy war between AP Racing and CSG about which non-PP kit is better, check out https://www.ft86club.com/forums/showthread.php?t=144662. Has most part numbers in the first post, and should be better for quick look-ups.
The Following User Says Thank You to timurrrr For This Useful Post:
Tokay444 (12-30-2021)
Old 01-02-2022, 09:15 AM   #136
gpvecchi
gpvecchi's Avatar
Do you know if the shims of the pads are adesive or clipped? Thanks!
gpvecchi is online now   Reply With Quote
Old 01-02-2022, 09:32 AM   #137
EndlessAzure
Wheels for Brains
If anyone has done a conversion on the fronts, would you know if the PP has a different design for the front dust shields? Or modified 13-16 Base shields to fit (other than removing them completely). Subaru parts diagrams showing conflicting info. Seems to have 4 part numbers across various diagrams I'm leaning toward PNs: 26290CA020 and 26290CA030 I have a set of Brembo GTs I'm preparing to install
SU00306803
SU00306804
It's been a while, but I did order and install the ducts from Subaru and they were the correct ones
Clip, sort of? At least for the fronts. However they don't grip tightly. There is only a c-shaped hanger that holds it to the top. The fit is loose and they flop off the pad pretty easily if they aren't installed in the caliper
I don't have any experience with the rears
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
gpvecchi (01-03-2022), MrSkubi (01-03-2022)
Old 07-01-2022, 08:42 PM   #138
bradsm87
Drives: It has 4 wheels
Here is a full list of the parts.
Note the front shield change is not needed and you can just cut the rear shield, which saves disassembling other things too.
It seems like the calipers are either far more expensive or just not available outside the US, even in Japan. I think I'll have to get the calipers, Posi-Quiet pads and centric front hardware kit from the US, get Brembo rotors locally and buy everything else from Japan. Subaru seems cheaper than Toyota for all parts.
For you lucky people in the USA, you can easily buy Centric Parts stuff so if you want a cheaper alternative, buying the following items means you don't need to buy the genuine pins, clips or springs:
Posi-Quiet ceramic front pads 105.10010
Centric Parts front hardware kit 117.47018
Posi-Quiet ceramic rear pads with hardware 105.09610
bradsm87 is offline   Reply With Quote
Old 07-01-2022, 09:13 PM   #139
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Have you seen this thread?
Follow the build thread for my GR86!
Old 07-01-2022, 10:48 PM   #140
bradsm87
Originally Posted by timurrrr View Post
Yep I have. You've done well. Thanks.
I thought the Toyota, Brembo and DBA PNs might come in handy as well as clarification of the shields and Centric hardware for those that don't know which pieces that the Centric hardware kits replace and that rear pads can be purchased including hardware. Also I left the repair kits out of my list.
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-12-2024 10:05 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
EVO 7 BREMBO FRONT BRAKES ON BRZ? NOTORIOUS.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-26-2016 12:24 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
