Old 02-09-2021, 10:50 AM   #43
jflogerzi
jflogerzi's Avatar
Originally Posted by vin08 View Post
gas is reaching $4 here in SoCal and E85 near my house that i just moved into 2 months ago is at 2.59. So i finally ordered a Flex fuel kit.
It comes out to be the same kinda but with more smiles per gallon
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Lantanafrs2 (02-09-2021)
Old 02-09-2021, 02:29 PM   #44
czellers
czellers's Avatar
Drives: 2K19 GT86
What kit did you decide on and how was the install?
czellers is offline   Reply With Quote
Old 02-09-2021, 08:44 PM   #45
Frankz54
Drives: 2019 Toyota GT86
Do it bro, you won't go back to 93.
Frankz54 is offline   Reply With Quote
The Following User Says Thank You to Frankz54 For This Useful Post:
Purist (02-10-2021)
Old 02-10-2021, 08:04 PM   #46
vin08
275/1000
Drives: 2016 RS2 auto
I already a have OFT and run stage 2 so i got a delicious kit for OFT. Trying to figure out how to install it since their online instruction sucks and is for the ecuteck kit.
vin08 is offline   Reply With Quote
Old 02-10-2021, 08:04 PM   #47
vin08
275/1000
I am. I already got the kit. lol
Old 02-10-2021, 10:56 PM   #48
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by DarkSunrise View Post
Do you have any data logs with your flex fuel setup? Just want to see how much timing you’re running on the top end under open loop. On my OFT non-flex e85 tune I’m hitting 34-35 degrees timing advance with local e85. I’d be surprised if MBT was beyond that, but your post is making me curious what flex fuel tunes are aiming for.
Not running E85/FF. it is almost nonexistent in my area. I have pulled up some V4 tunes and compared them to mine based of v2.7, the OTS E85 tune's timing tables are almost as mild as I am running on 91. There are a lot of other benefits to E85 besides octane, but if you have it why not run the timing to take full advantage.
Old 02-11-2021, 02:01 AM   #49
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I think mine is different
The Following User Says Thank You to gen3v8 For This Useful Post:
NoHaveMSG (02-11-2021)
Old 02-11-2021, 09:47 AM   #50
czellers
czellers's Avatar
Drives: 2K19 GT86
I believe the difference stems from the different calibration codes.. or possibly the file version (2. vs 4.)
Old 02-11-2021, 12:25 PM   #51
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interesting, looks a bit closer to what I was expecting to see. Still seems a bit mild though.
Though a quick google search shows that Australian spec E85 is to be from between 70-85% ethanol. So tighter tolerance then here in the states.
Old 02-11-2021, 12:49 PM   #52
DarkSunrise
DarkSunrise's Avatar
Probably easier to look at a datalog for total timing (or ignition advance) since KCA will get added in.
For example, my car on the standard non-flex OFT 4.03 e85 tune runs about 34 degrees timing near redline.
https://datazap.me/u/darksunrise/202...2771-2770-2772
I was curious if FF cars are pushing more than that. I’d be really surprised if they are because from what I understand that’s pretty much MBT, but a datalog from a FF car would be the easiest way to compare.
2022 BRZ Build
2013 FR-S Build
Old 02-11-2021, 12:53 PM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I didn't think of that, that is a good point.
Looking to get new wheels - please advise ThaDonJsuan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-20-2021 02:51 PM
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 05:10 PM
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 09:02 PM
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 06:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 04:13 PM
