Old 12-08-2020, 09:24 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Parking brake "delete"
So if you get rid of the parking brake the wheel bearing needs the spacing of the drum brake backplate to mount the rotor and wheel bearing at the right offset. 3/8 thick 7075 Aluminum 6x6", a 83mm hole saw, a drill press, a grinder and about 4 hours you can make some plates. Not perfect but will work.
The Following 4 Users Say Thank You to ML For This Useful Post:
DarkPira7e (12-08-2020), DIY (12-10-2020), SCFD (01-18-2021), soundman98 (12-09-2020)
Old 12-09-2020, 03:05 AM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Love it dude! Always impressed by people who fabricate their own parts.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
ML (12-09-2020)
Old 01-15-2021, 12:31 PM   #3
WheelrDealer
WheelrDealer's Avatar
Drives: 2016 FR-S
I was thinking of deleting the parking brake on my 86 track car. May I ask why the spacers? Thanks, Bill
Wheelrdealer Racing
WheelrDealer is offline   Reply With Quote
Old 01-15-2021, 02:33 PM   #4
ML
ML's Avatar
because if you get rid of the entire parking brake assembly and don't use spacers then the brake rotor will no longer be the right offset for the caliper.
Old 01-17-2021, 06:18 PM   #5
WheelrDealer
Drives: 2016 FR-S
Thanks, I will make a pair.
Bill
Wheelrdealer Racing
Old 01-18-2021, 02:14 PM   #6
Icecreamtruk
Drives: Track preped NA FRS
I went the redneck route, cut the backblack/dustshield with a grinder and leave it somewhat similar to what you have there :P
Icecreamtruk is offline   Reply With Quote
Old 02-04-2021, 11:33 AM   #7
WheelrDealer
Drives: 2016 FR-S
spacers
One last question, are you not using the original style rear rotors that have the drum in the center? I have measured mine and installed the calibers and have normal clearance. Now if I install a front rotor on the rear it is off by about 3/8" requiring a spacer.
Thanks,
Bill
Wheelrdealer Racing
Old 02-04-2021, 01:23 PM   #8
ML
ML's Avatar
Thanks,
Bill
yes I was using the original rotors just with no drum brake. I don't know anything about putting a front rotor on the rear. seems like it would make sense that it wouldn't line up.
Old 02-04-2021, 04:59 PM   #9
WheelrDealer
Drives: 2016 FR-S
rotors
Thanks, mine seem to line up now. I have not run the lugs down on a wheel yet. I will check again and see if the rotor binds. Thanks for the feedback.
Bill
Wheelrdealer Racing
Old 02-10-2021, 05:39 PM   #10
ROADRACER
Drives: unlimited cheap build N/A track car
Is this mod just to save weight or are there other reasons?
ROADRACER is offline   Reply With Quote
Old 02-12-2021, 07:46 AM   #11
ML
ML's Avatar
sorta...I have inline hydraulic handbrake so don't need the parking brake, and only have one rear caliper.
The Following User Says Thank You to ML For This Useful Post:
Wally86 (05-29-2021)
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
Just changed pads and fluid; brake pedal has more "dead space" ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-13-2015 02:56 AM
Forcewerkz "Fang Delete" Polyurethane Front Lip Spoiler - Scion FRS unionperformance Exterior Parts - The Rest 7 02-06-2014 07:07 PM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
Limited gets brake "upgrade" over Premium - Canada only? Sport-Tech BRZ First-Gen (2012+) — General Topics 25 05-15-2012 12:35 AM
