Drives: 2014 BRZ
Weird humming/winding nose/tire noise?
I’m hearing this wired humming? Winding noise? Kinda reminds me of a truck with large tires on.
Car runs great, no vibrations nothing that seems to affect the cars drivability See clip for noise - Any thoughts? Thank you |
#2 |
Have you done anything to your car recently? Not necessarily mods, but even maintenance items?
#3 |
Drives: 2014 BRZ
#4 |
#5 | |
Drives: 2014 BRZ
Tires are pretty new only about 2k miles I’ll try rotating the wheels this weekend And pressure is good Thank you |
| The Following User Says Thank You to Antuono For This Useful Post: | humfrz (01-28-2021) |
#7 | |
At the same time, have the front wheel bearings checked. It's possible, but not likely, you have a defective tire (like the cords have separated). Happy hunting -
#8 |
Drives: 2013 WRB BRZ
Sounds like a wheel bearing to me
#9 |
Drives: 2014 BRZ
What’s the best way to check a bad wheel bearing? I lifted the car checked all the wheels for movement, even took off the wheels and checked for movement. Would I need to take off the brake calipers to check that?
I think your right but can’t seem to find which wheel is the asshole. |
| The Following User Says Thank You to Antuono For This Useful Post: | humfrz (01-30-2021) |
#10 | |
Sometimes, one can tell by driving down a smooth road and turn the steering wheel from side to side and see if the bearing screams at you. OR, do it the humfrz way, take the car into a shop and ask them to check the wheel bearings and replace them if necessary -
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | LimitedSlip (01-31-2021), soundman98 (01-30-2021) |
#11 |
Drives: 2014 BRZ
#12 |
| 2016 FR-S making Weird winding sound | xanielxx | Issues | Warranty | Recalls / TSB | 17 | 11-24-2018 07:47 PM |
| Weird humming noise from behind radio in middle of dash | JesseE | Issues | Warranty | Recalls / TSB | 6 | 10-17-2016 06:50 PM |
| Humming noise while driving | maylchi | Issues | Warranty | Recalls / TSB | 9 | 03-13-2015 01:29 AM |
| help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 12:16 PM |
| Winding Noise From Clutch | Bach415 | Northern California | 0 | 06-24-2013 07:19 PM |
